Richard.Kent
This is an old trick that most may already know. Lets say you have several lines (or even just one) and they are not drawn exactly ortho, maybe they all have an angle of 1 degree, or one is at 1 degree, one is at 10 degrees, etc. and they should all be zero degrees. Start CHANGE command, pick the lines, enter, set Ortho to on, pick a point. Just like that they are now all at zero angle, and they maintain their other end point.
Now lets say those same lines need to stop perp to a line that is at 90 degrees, and some of the lines extend beyond the vertical line and some stop short. Use CHANGE, select the lines, enter, Perp, select the vertical line.
There will be some limitations as you use this tip. If you pick lines that are further apart than they are long then some will end up vertical while other are horizontal. A minor set back but one you should know about.
Obviously one can rotate the UCS to any angle and use the tip in that way also.
