Results 1 to 1 of 1
Thread: Support for AECC Objects in Queries
    Cairo - no, not Illinois
    5,054
    Default Support for AECC Objects in Queries
    Description: Update Map to enable querying for Civil3d objects, in particular querying on AECC Points and Feature Lines
    How Used: It would be helpful to bring in information held as AECC Points and Feature Lines from a source drawing into the active drawing. Especially being able to generate ad-hoc queries of AECC Points based on layer, location or that fall within a buffer zone. Frequently I have a need to look at point information in a design file, and need a simple way to bring in the AECC Points at a specific location or within a specific area to see what the surveyed elevation, point number, or assigned description was. Adding support for AECC Points and feature lines would help in doing that significantly.
    Feature Affinity: Queries
  1. 2014: Plant 3d support civil 3d objects
    By dtham384694 in forum AutoCAD Plant 3D - Wish List
    Last Post: 2013-11-15, 08:49 AM
  2. Linetype support for 3D objects
    By gene.evans29 in forum AutoCAD Map 3D - Wish List
    Last Post: 2007-05-18, 12:19 PM
  3. Does AutoCAD support Importing of RPC Objects
    By jarkko.rasanen in forum AutoCAD General
    Last Post: 2006-04-04, 02:58 PM
  4. AECC Contours
    By afortier in forum AutoCAD Civil 3D - General
    Last Post: 2005-06-01, 05:54 PM
