Results 1 to 6 of 6
Thread: autocad 14 highlight will not "highlight"
    2004-08
    4
    Question autocad 14 highlight will not "highlight"
    setvar=1 erase,copy and similar commands will work except the lines, for example,
    will not dot ( highlight )
    13,656
    Default Re: autocad 14 highlight will not "highlight"
    Hi
    Please note I've *moved* this Topic (Thread) from the CAD Management Software Forum to this one as I believe it would be better served here.
    Thanks, Mike
    Forum Moderator
    13,656
    Hi
    Has this only recently started to occur?
    If yes, have you upgrade hardware recently?
    If yes check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TS66174 - Object selection highlighting does not work even though HIGHLIGHT system variable is set to 1
    If no, does this occur in all drawing files?
    Have a good one, Mike
    100 Club Lemons's Avatar
    2001-06
    Beautiful Charleston, SC
    182
    Check your dimscale, ltscale and the individual ltscale of entities.
    I've seen this before and it was just mismatched/wrong ltscale/entity ltscale that was the problem.
    Celie
    2004-08
    4
    Quote Originally Posted by Mike.Perry
    Hi
    Mike Perry this is new equipment in last 3 months, will check into your "fix" idea thanks Ron
    2004-08
    4
    Quote Originally Posted by cdailey
    Celie
    Cdailey thanks for your suggestion will give it a try Ron
  1. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  2. Unable to highlight Object sby "hovering over" with mouse.
    By pirit4 in forum Revit Architecture - General
    Last Post: 2011-10-17, 06:20 PM
  3. Replies: 2
    Last Post: 2008-11-17, 02:17 PM
  4. "Auto-highlight"
    By boofredlay in forum Revit Architecture - General
    Last Post: 2006-10-19, 08:44 PM
  5. Turning off the auto-Highlight in Autocad 2006
    By VBOYAJI in forum AutoCAD General
    Last Post: 2005-12-15, 08:03 PM
