View Poll Results: Vista Users - Does Windows Explorer display Revit thumbnails correctly?
Voters
75. You may not vote on this poll
  • Yes it does
    15 20.00%
  • No it doesn't
    58 77.33%
  • It didn't before but now it does
    2 2.67%
Page 2 of 7 FirstFirst 123456 ... LastLast
Results 11 to 20 of 68
Thread: Thumbnail Previews in Windows Vista
  1. #11
    Count (Formula) dbaldacchino's Avatar
    2005-07
    Missouri City, Texas (Houston area)
    3,250
    Default Re: Thumbnail Previews in Windows Vista
    Ian, I'm on your same OS and at some point, the thumbnails quit working (actually it was the icons more than anything). I re-installed Revit Architecture and that fixed it for me. I can now reliably see icons and thumbnails. I'll be installing RST and RMEP soon and I'll see if that changes things, as I've heard reports that other versions (namely a mix of 64 & 32 bit Revit apps) mess things up.
  2. #12
    2007-06
    Melbourne, Australia
    602
    Dave,
    There are some posts around which indicate that everything shows up ok if you have RST installed. I would be interested to know if the installation of RST resolves it for you. (If so, maybe the factory will just issue me a copy of RST & be done with it?!?)
    In my case, it was a complete clean install of both the operating system & RAC. I have ended up with no thumbnails, however when loading a family the mouse scrolls past the preview of the family appears in the preview window.
    Given that Christmas is with us now, I plan to do yet another clean install and upgrade to WU3!!
    Cheers, Happy Christmas & thanks for all your help during the year. Without you & the others here I would still be fumbling in the dark over so many matters.
    Ian
  3. #13
    2005-07
    3,250
    Ian, in my case re-installing RAC resolved the issue. So hopefully that will fix it for you too.
  4. #14
    I could stop if I wanted to Marek Brandstatter's Avatar
    2003-08
    Johannesburg, South Africa
    214
    You can try this:
    Click Vista's Start button
    In the Search box, type Cmd
    Right-click on Command Prompt in the search result listing
    Click “Run as Administrator"
    Type regsvr32 "c:\program files\revit architecture2009\program\revitpreview.dll"
    The above "correctly" registers revitpreview dll.
    Last edited by Marek Brandstatter; 2008-12-22 at 07:58 PM. Reason: added full pathing to revitpreview.dll
  5. #15
    2007-06
    602
    Hi Marek
    Thanks for the suggestion. I gave it a whirl but windows came up with an error:
    "The module "revitpreview.dll" failed to load.
    Make sure the binary is stored at the specified path or debug it to check for problems with the binary or dependant .DLL files.
    The specified module could not be found."
    The dll exists and is in the correct location. I have updated my support request with this info. I will let you know how it goes.
    Ian
  6. #16
    2003-08
    214
    Ian, what if you try with full pathing? eg.
  7. #17
    2007-06
    602
    Marek
    I had tried the full path yesterday, but I just gave it another go just in case I had dyslexic fingers yesterday. Same result - same error message.
    Cheers,
    Ian
    PS Congrats on the cricket win
  8. #18
    2003-08
    214
    Quote Originally Posted by iankids
    Thanks, it's a funny game. Two more to go.
    I've asked Louis to help out here. We've managed to get thumbnails working on all machines where we've encountered the problem.
  9. #19
    2007-06
    602
    Talking Re: Thumbnail Previews in Windows Vista
    Full marks and a hearty thank you to Marek and his team at CadPlan.za. With the help of Louis from his office they managed to fix the windows vista problems in a flash!!!!
    Marek's earlier suggestion was actually spot on the money.
    worked a treat. the bit I left out when doing it myself was the " "
    When using the complete string, including the " ", everything is as it should be and I once again have previews on all of the families in the windows explorer.
    Once again, thanks so much.
    Cheers & happy Christmas
    Ian
  10. #20
    I could stop if I wanted to Mike Hardy-Brown's Avatar
    282
    Nice Marek / Louis
  1. Thumbnail Previews
    By louis.64641 in forum AutoCAD Customization
    Last Post: 2009-06-01, 06:43 PM
  2. previews of Revit project Files and Families in the Windows Explorer
    By nihar.ranjan in forum Revit Architecture - General
    Last Post: 2008-11-24, 10:01 AM
  3. Any Fix to Displaying Thumbnail in Vista 32 Bit
    By Jason in forum Revit Architecture - General
    Last Post: 2008-11-20, 07:01 PM
  4. Nicer looking thumbnail previews
    By SCShell in forum Revit Architecture - Tips & Tricks
    Last Post: 2007-02-26, 06:11 AM
  5. Previews & Thumbnail with Vault
    By KellyR in forum Inventor - General
    Last Post: 2005-09-19, 11:32 AM
