can "calculated value" be used to get the summation of
one individual column values in a schedule ?
Thanks
WF
Thanks
WF
No, if you want a grand total at the bottom of a column...
Edit Schedule properties
Click formatting Tab > select column parameter name > Click Calculate Totals
Click Sorting/Grouping tab > Check the Grand Totals box
Partially correct , Steve.
It doesn't work for foundation families. I introduced a shared parameter
for the number of piles used in a pile cap, but just can't sum up the result
in a schedule inside the project file, nor other parameters like width, length ..etc.
What is the datatype of the parameter? If it isn't a number, length or area for example it won't calculate the total. Simpler to say it won't calculate the total if the datatype is text.
