Thread: Combine DWG TrueView 2008 with Design Review 2008
    2004-08
    Default Combine DWG TrueView 2008 with Design Review 2008
    Combine DWG TrueView 2008 with Design Review 2008 to make a nice complete package to view dwg, dwf, and images or at least give the same capabilities as Design Review into TrueView.
    For instance it would be nice to be able to measure a distance or area in TrueView like you can in Design Review.
    How Used : It would benefit any users that don't have Autocad installed and would like to view a DWG and DWF's within one program and have the capabilities to measure distance and area and print.
    Earth
    9,780
    Exclamation Re: Combine DWG TrueView 2008 with Design Review 2008
    Autodesk's current position on this:
    Quote Originally Posted by http://discussion.autodesk.com/thread.jspa?messageID=5207647
    Autodesk Design Review ... comes with the ability to open a DWG and convert
    it to DWF on the fly. You can then take measurements against the DWF.
    From a user perspective, the software will act as if you are measuring a
    DWG. Autodesk has many formats that need to be measured: DWG, RVT, IPT, etc.
    Centralizing the measurement on DWF allows us to provide capabilities for a
    wide variety of industries.
    Quote Originally Posted by http://discussion.autodesk.com/thread.jspa?messageID=5417990
    Autodesk DWG TrueView views a DWG file and can publish a DWF.
    Autodesk Inventor View views IAM, IPT, and IDW files and can publish a DWF.
    Autodesk Revit works with RVT files and can publish a DWF.
    Rather than have to provide measurement capabilities for all of these
    different formats, we have standardized on DWF.
    Autodesk Design Review will let you measure distances and areas in a DWF. If
    you import a DWG into Autodesk Design Review, it will convert it to DWF on
    the fly.
    R.K. McSwain | CAD Panacea |
  1. Can Design Review 2008 be loaded on a Citrix server?
    By mikesal in forum Design Review - General
    Last Post: 2008-03-22, 04:49 PM
  2. Replies: 3
    Last Post: 2007-11-21, 10:05 PM
  3. Printing Issues with Design Review 2008
    By sinc in forum Design Review - General
    Last Post: 2007-08-22, 01:00 PM
  4. Import DWG with Xref's into Design Review 2008 with Trueview
    By benmay in forum Design Review - General
    Last Post: 2007-06-05, 12:42 PM
  5. What's new in Autodesk Design Review 2008
    By scott.sheppard in forum Design Review - General
    Last Post: 2007-05-15, 03:28 AM
