It's easy. Took me about 3 min total (only because I had to remember what I was doing). You start with the profile of the star. Split off one leg. Turn it into a mass element. Then you simply use the split face command from the right click options. When you select the mass again you should see a bunch of grips. You can push & pull these in just about any direction you want. When strecthing them, by pressing the contol key you can get a bunch of differnt functions. By pressing the tab key you can flip thru all the points on the mass. These things are just so much fun to play with.
