How do I create a dimension style that will show dimensions in inches and fractions of inches instead of feet and inches, e.g, 42-1/2" instead of 3'-6 1/2"
Jeff
Jeff
Your dimstyle should be of type "fractional" not architectural. That should do it.
Make sure to include the inch mark as a suffix under the "primary units" tab of you dimstyle
Okay, that gives the dimension in inches, but it's rounding off to the nearest inch, even though I have the "round off" set at 1/8" in the Primary Units/Linear Dimensions dialog box.
What it the actual distance you are dimensioning? What do you get when you set the round off to 0.0?
You got it. I had the precision set to zero. Thanks to all for pointing me in the right direction.
Jeff
