Results 1 to 10 of 12
Thread: Convert to PDF
    2004-06
    32
    Unhappy Convert to PDF
    How do I save my dwg as a pdf file?
    2007-08
    42
    Default Re: Convert to PDF
    The only way I know is to print to a PDF Printer like PDF Creator or Bluebeam.
    2004-07
    Detroit Michigan
    2,508
    PDF995 is free. Google it.
    Earth
    9,800
    Quote Originally Posted by mickb View Post
    You don't 'convert' to PDF.
    A PDF file is the output from plotting.
    Run the plot command, and select your PDF print driver.
    R.K. McSwain | CAD Panacea |
    2007-09
    31
    When I create a pdf in acad 07 it puts the paper size and pdf file suffix twicw.
    how do I stop this?
    Earth
    9,800
    Quote Originally Posted by ekohles View Post
    how do I stop this?
    Can you explain?
    Do you mean it adds this to the plot file name or is there a problem in the dialog?
    2003-03
    2
    Smile Re: Convert to PDF
    Quote Originally Posted by MARPOW View Post
    You can also use a third-party software like Slick! PdfPlus which also does batch conversion. You can download a demo from www.slickwin.com/slickpdfplusdownload.html.
    2007-09
    31
    i pick DWG to PDF in the printer / ploter selection area in the plot model dialog box.
    when i hit print, i am promopted to path it to where i want it saved.
    it automaticly uses the file name that i have it saved as
    but it adds the paper size dimmensions + .pdf.
    when i hit save the file name looks this,
    "filenamre"-"papersize".pdf.pdf
    Active Member s_morgan_b's Avatar
    2007-01
    Cowtown
    90
    Is it actually adding the name of your viewport? Is your viewport labeled as your paper size?
    "That's 2 cm difference."
    "How much is that in mm?"
    2007-09
    31
    i don't name the viewports, howerver the drawing tabs are broke up into sheet sizes.
    not sure why it would pull info from that though?
  1. 2010: convert dgn to dwg
    By mkr_trash in forum AutoCAD General
    Last Post: 2012-10-08, 12:24 PM
  2. Convert a PDF into a DWG
    By huuthu_nguyen82544 in forum AutoCAD LT - General
    Last Post: 2006-08-18, 01:02 AM
  3. Convert DWG to PCX
    By mreynolds9 in forum AutoCAD 3D (2006 or below)
    Last Post: 2006-03-31, 08:52 AM
  4. Replies: 9
    Last Post: 2005-06-29, 09:49 PM
