Results 1 to 10 of 12
Thread: Is Xrefs a variable?
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Default Is Xrefs a variable?
    Hi ALL,
    A drawing external reference can be shown by using rtext with following diesel expression:
    $(xrefs, ,)
    However, I can not found "xrefs" as a vaiable in autocad help menu.
    I can not apply the above to lsp routine.
    Is there anyone can tell what xrefs is & how does it work in lsp routine.
    I am using AutoCAD 2005 mechanical.
    Ke
    100 Club CADmium's Avatar
    2004-08
    Eberswalde, Germany, Europe
    128
    Default Re: Is Xrefs a variable?
    try this Code:
    (defun XREFLIST(/ LISTE)
      (vlax-for BLOCK (vla-get-blocks(vla-get-activedocument(vlax-get-acad-object)))
        (if(=(vla-get-isxref BLOCK):vlax-true)
          (setq LISTE (cons (strcase(vla-get-name BLOCK))  LISTE))
      (mapcar
        '(lambda(X / Y)
           (if(and(setq Y(ssget "_x" (list '(0 . "INSERT")(cons 2 X))))
                  (setq Y(ssname Y 0))
                  (setq Y(vlax-ename->vla-object Y))
                  (setq Y(vla-get-path Y))
             Y
        LISTE
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Quote Originally Posted by ke.li View Post
    . . .I can not found "xrefs" as a vaiable. . .
    No there is no variable storing xrefs.
    Is there anyone can tell what xrefs is . . . .
    an Xref is a block/nested drawing that you can separate from ordinary block in current drawing, but if you do not know the name
    you have to iterate trough all blocks in the definition table and look for dxf code 1 or 70
    code 1 tells you a path to the dwg file, and code 70 tells you the status of the xref, in next example 44 is overlay.
    . . .& how does it work in lsp routine. . .
    If you do not know the name
    (tblnext "BLOCK" T ) ; the very first block
    (tblnext "BLOCK" nil ) ; following blocks (70 . 44) (1 . "path") = xref
    (tblnext "BLOCK" nil ) ; (70 . 0) no code 1 = ordinary block
    if you know the name
    (tblsearch "BLOCK" "MyBlock" ) ; (70 . 0) no code 1 = ordinary block
    (tblsearch "BLOCK" "MyXref" ) ; (70 . 44) (1 . "path") = xref
    if you know the name { more dxf code }
    (entget (tblobjname "BLOCK" "MyBlock" ) ) ; (70 . 0) (1 . "") = ordinary block
    (entget (tblobjname "BLOCK" "MyXref" ) ) ; (70 . 44) (1 . "path") = xref
    (defun XrList (/ BlockName BlockList XrefList )
      (setq BlockName (cdr (assoc 2 (tblnext "BLOCK" T ))) )
      (while BlockName
        (setq BlockList (append BlockList (list BlockName )) )
        (setq BlockName (cdr (assoc 2 (tblnext "BLOCK" nil ))) )
      (foreach Block_In BlockList
        (setq XrefList (append XrefList (list (cdr (assoc 1 (tblsearch "BLOCK" Block_In ))))))
      (setq XrefList (vl-remove nil XrefList ))
    Usage
    Command: (XrList)
    : ) Happy Computing !
    kennet
    All AUGI, all the time Avatart's Avatar
    2004-06
    Upsidedown in dreamtown
    928
    Alternatively, I use this code to return a selection set of Xrefs:
      (setq InsertList (ssget "X" '((0 . "INSERT"))))
      (while (< 0 (sslength InsertList))
        (if (/= nil (assoc 1 (setq Xref-Block (tblsearch "BLOCK" (cdr (assoc 2 (setq Xref-Insert (entget (ssname Insertlist 0)))))))));if
          (progn
     (setq XrefList (append XrefList (list Xref-Block)))
     (setq InsertList (ssdel (ssname InsertList 0) InsertList)));then
          (setq InsertList (ssdel (ssname InsertList 0) InsertList)));else
    2004-06
    928
    Looks like Kennet and me were doing the same thing at the same time!
    Kennet!
    2002-05
    1,707
    Quote Originally Posted by carl_hd_collins View Post
    Kennet!
    Yes, but you are missing the "other space" in your code ; )
    this code create two lists of dxf codes,
    one for xrefs = XrefList
    and one for blocks = BlockList
    (setq BlockDXF (tblnext "BLOCK" T ) )
    (while BlockDXF
      (if (= (logand 4 (cdr (assoc 70 BlockDXF )) ) 4 )
        (setq XrefList  (append XrefList  (list BlockDXF )) )
        (setq BlockList (append BlockList (list BlockDXF )) )
      (setq BlockDXF (tblnext "BLOCK" nil ))
    kennet
    2004-06
    928
    Quote Originally Posted by kennet.sjoberg View Post
    (while BlockDXF
    kennet
    That's because you are a better Lisper than me.
    2006-04
    1,160
    kennet
    Hi Guys,
    Sorry for the late response as I was too busy to finish my work - I am not the boss, unfortunately...
    I tried your code & works well. Thanks for your wonderful tips!
    Ke
    2005-07
    40
    I was looking into certain aspects of this myself and I found your posts here very helpful.
    Rob
    2004-06
    928
    Quote Originally Posted by rmiller.90409 View Post
    Rob
    Glad be of service (even if my code was not as as Kennets)
  1. Replies: 11
    Last Post: 2010-04-08, 09:03 PM
  2. Project Navigator - xrefs? what xrefs?
    By rodg in forum CAD Management - General
    Last Post: 2008-11-04, 08:21 AM
  3. Project Navigator - xrefs? what xrefs?
    Last Post: 2008-11-04, 08:20 AM
  4. Variable height/variable count family (studs in a sloped wall)
    By DoTheBIM in forum Revit Architecture - Families
    Last Post: 2006-06-15, 02:48 PM
  5. XREFS - MSG not xrefs "Not Found"
    By spencer.67965 in forum VBA/COM Interop
    Last Post: 2005-01-18, 03:45 PM
