Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 53
Thread: trying to write rev routine - need help with cond statement
    2007-05
    Brookfield WI
    331
    Default trying to write rev routine - need help with cond statement
    I can get it to ask the question but can't it to begin pline...not sure if my "if" is correct...
    (defun C:rv (/ inp)
        (setq OldLayer (getvar "CLAYER" ) )        ; save current settings current layer
      (initget 0 "1 2 3" ) ; ask for input
      (setq Inp
        (cond
          ((getkword "\nWhich Revision is this? [1/2/3] <1>: " ) );get keyword from user
          ( "1" ) ;default keyword
        (if (= Inp "1" ) ; check the input and create/set layer
        (progn
          (if (not (tblsearch "LAYER" "rev1" )) ; if the layer does not exist, create it
            (command "_.layer" "n" "rev1" "c" "green" "rev1" "lt" "continuous" "rev1" "" )
            ( ) ; if the layer exist
    ;;;      (setvar "CLAYER" rev1) ; set the layer current
        (progn
          (if (not (tblsearch "LAYER" "rev2" )) ; if the layer does not exist, create it
            (command "_.layer" "n" "rev2" "c" "green" "rev2" "lt" "continuous" "rev2" "" )
    ;;;      (setvar "CLAYER" rev2) ; set the layer current
        (progn
          (if (else (tblsearch "LAYER" "rev3" )) ; if the layer does not exist, create it
            (command "_.layer" "n" "rev3" "c" "green" "rev3" "lt" "continuous" "rev3" "" )
    ;;;      (setvar "CLAYER" rev3) ; set the layer current
      );end of if
      (command "._pline") ; create objects draw pline
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: trying to write rev routine - need help with cond statement
    Maybe this would be easier and doesn't limit you to three revs?
    (defun C:rv (/ Oldlayer Oldcmdecho inp layname)
      (setq OldLayer (getvar "CLAYER" ))         ; save current settings current layer
      (setq OldCmdecho (getvar "cmdecho"))   ; save current cmdecho
      (setq inp (getint "Revision Number: "))    ; get revision number as integer
      (setq layname (strcat "rev" (itoa inp)))   ; add the integer to rev
      (if (tblsearch "layer" layname)            ; if the layer exists...
        (setvar "clayer" layname)		     ; just set it
        (progn                                   ; else create it, then set it
          (command "_.layer" "n" layname "c" "green" layname "lt" "continuous" layname "")
      (command "pline")                          ; start the pline command
      (setvar "cmdecho" 1)                       ; turn on cmdecho so you can see the pline prompts
      (while (= 1 (logand (getvar "CMDACTIVE") 1))(command pause)) ;draw the pline
      (setvar "cmdecho" Oldcmdecho)              ; reset cmdecho
      (setvar "clayer" Oldlayer)                 ; reset layer
      (princ)
    HTH
    2007-05
    Brookfield WI
    331
    Quote Originally Posted by timcreary View Post
      (princ)
    HTH
    thats pretty cool code, but the reason I want to write it the way I had it is so that I can insert the rev sym per user input.
    I have stuff to add to it yet, to be continued later I guess
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    This should do it.
     (defun C:rv (/ inp)
      (setq Inp (getkword "\nWhich Revision is this? [1/2/3] <1>: " ) );get keyword from user
      (princ "\nInp = ")(princ Inp)
      (cond
        ((or(= Inp "1" )(= Inp nil)) ; check the input and create/set layer
          (if (tblsearch "LAYER" "rev1" )(command "_.layer" "t" "rev1" "")) ; can't set a frozen layer current
          (command "_.layer" "m" "rev1" "c" "green" "rev1" "lt" "continuous" "rev1" "" )
        ((= Inp "2" ) ; check the input and create/set layer
          (if (tblsearch "LAYER" "rev2" )(command "_.layer" "t" "rev2" "")) ; can't set a frozen layer current
          (command "_.layer" "m" "rev2" "c" "green" "rev2" "lt" "continuous" "rev2" "" )
        ((= Inp "3" ) ; check the input and create/set layer
          (if (tblsearch "LAYER" "rev3" )(command "_.layer" "t" "rev3" "")) ; can't set a frozen layer current
          (command "_.layer" "m" "rev3" "c" "green" "rev3" "lt" "continuous" "rev3" "" )
        (T (princ "\nI give up!"))
      );end of cond
      (while (= 1 (logand 1 (getvar "cmdactive")))
        (command PAUSE)
      (setvar "CLAYER" OldLayer)        ; restore current layer
      (princ "\nIt worked!")
      (princ)
    2001-03
    Tallahassee, FL USA
    3,667
    Stealing ideas from CAB2k and trying to avoid messy -layer command calls. This is better.
    (defun C:rv (/ inp rev OldLayer)
      (setq OldLayer (getvar "CLAYER")) ; save current settings current layer
      (initget "1 2 3 4") ; ask for input
      (setq Inp (getkword "\nWhich Revision is this? [1/2/3/4] <1>: "))
      (or Inp (setq Inp "1"))
      (setq rev (strcat "rev" Inp))
      (setq doc  (vla-get-activeDocument (vlax-get-acad-object)) ;;;get current drawing
           lyrs  (vla-get-layers doc)                            ;;;get layer collection
           name (strcat "rev" Inp)
      (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list lyrs name))) ;;;check to see if layer exists
        (setq lyr (vla-add lyrs name)) ;;;add new layer to layer collection and capture the new layer
        (setq lyr (vlax-ename->vla-object (tblobjname "layer" "rev1")))
      (vla-put-Color lyr 3)      ;;;change the color of the new layer
      (vla-put-LineType lyr "Continuous")   ;;;change the linetype of the new layer
      (vla-put-Freeze lyr 0)      ;;;thaw the new layer
      (vla-put-LayerOn lyr -1)      ;;;turn the new layer on
      (vla-put-Lock lyr 0)      ;;;unlock the new layer
      (setvar "CLAYER" name) ; set the layer current
        (command PAUSE)
      (princ)
    2007-05
    Brookfield WI
    331
    how about this?
    I have a 3 routines...
    One for rev 1, one for rev 2, and one for rev 3
    each routine puts text on our TB REV 1 9/22/07 with a revision symbol next to the text, then you cloud what changed and the rev symbol comes in at the pointer and is placed by the user.
    How can I use a condition statement that would run the proper routine based on user input?
    If 1 run rev1 if 2 run rev2 if 3 run rev3......make sense?
    If I can figure out ifs I could do so much more, in the learning process so please bear with me.
    All AUGI, all the time CAB2k's Avatar
    2016-01
    Brandon, Florida
    687
    Without seeing the other routine I can not guarantee this will work but the idea
    is as follows. Based on Tom's last routine.
      (cond
        ((= inp "1")  (rev1_routine))
        ((= inp "2")  (rev2_routine))
        ((= inp "3")  (rev3_routine))
      (princ)
    But note that you can alter the rev routines and make one routine out of them.
    If you post the routine someone will help you accomplish that.
    2007-05
    Brookfield WI
    331
    thanks I will post the routines Monday, as they are stored on my PC at work
    2007-05
    Brookfield WI
    331
    Quote Originally Posted by d_m_hopper View Post
    here are the three routines, currently in a pulldown menu....I would like to combine them based on user input..
    **REV1**
    (defun triangle1 ()
       (command
          "polygon" "3" bp "c" "5"
       (setq tr (list (car bp) (+ (cadr bp) 10)))
       (command
          "ortho" "off"
          "move" tr "" bp pause
    (setvar "filedia" 0)
    (setq tx (getvar "lastpoint"))
       (command
          "color" "magenta"
          "text" "s" "dmt" "j" "m" tx "0" "1"
          "color" "green"
       (setq tr (list (car (getvar "lastpoint")) (+ (cadr (getvar "lastpoint")) 10)))
       (command
          "copy" "c" tx tr "" tx "1598.7021,-997.0960"
       (setq id (list '1610.7021 '-1002.0960))
       (command
          "text" "s" "dmt" "j" "bl" id 0
       (prompt "\nInitials and Date, <ex. ABC - 4/16/93>: ")
    (setvar "filedia" 1)
    (defun c:rev1 ()
       (princ)
       (setq sp nil)
       (setq bp nil)
       (setq ep nil)
       (setq sp (getpoint "Startpoint of Rev.1 Cloud: "))
       (setq bp sp)
       (while
          (not (equal ep bp))
          (command
             "arc" sp pause pause
          (setq ep (getvar "lastpoint"))
          (setq sp ep)
    (triangle1)
    **REV2**
    (defun triangle2 ()
       (command
       (command
          "ortho" "off"
       (command
          "color" "magenta"
          "text" "s" "dmt" "j" "m" tx "0" "2"
          "color" "green"
       (command
          "copy" "c" tx tr "" tx "1598.7021,-1021.0960"
       (setq id (list '1610.7021 '-1026.0960))
       (command
    (defun c:rev2 ()
       (princ)
       (setq sp nil)
       (setq bp nil)
       (setq ep nil)
       (setq sp (getpoint "Startpoint of Rev.2 Cloud: "))
       (setq bp sp)
       (while
          (not (equal ep bp))
          (command
          (setq sp ep)
    (triangle2)
    **REV3**
    (defun triangle3 ()
       (command
       (command
          "ortho" "off"
       (command
          "color" "magenta"
          "text" "s" "dmt" "j" "m" tx "0" "3"
          "color" "green"
       (command
          "copy" "c" tx tr "" tx "1598.7021,-1045.0960"
       (setq id (list '1610.7021 '-1050.0960))
       (command
    (defun c:rev3 ()
       (princ)
       (setq sp nil)
       (setq bp nil)
       (setq ep nil)
       (setq sp (getpoint "Startpoint of Rev.3 Cloud: "))
       (setq bp sp)
       (while
          (not (equal ep bp))
          (command
          (setq sp ep)
    (triangle3)
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Would this Revision Cloud routine work for you? You would need to create an attributed block for your numbered triangle.
    Most of the three routines are similar. There is a difference in each routine on the (command "copy"... and the (setq id.. lines. Other than that, they are the same routine.
  1. Replies: 16
    Last Post: 2012-07-16, 07:41 PM
  2. COND Statement to Setq Variable
    By stusic in forum AutoLISP
    Last Post: 2012-04-05, 08:47 PM
  3. Routine skipping over cond. statement. . why?
    By M. Kubitza in forum AutoLISP
    Last Post: 2010-01-13, 11:04 PM
  4. Using commands in a cond statement
    By eleonard in forum AutoLISP
    Last Post: 2007-02-27, 06:07 PM
  5. Replies: 12
    Last Post: 2006-01-10, 09:38 PM
