Thread: Convert Layers to Standard
    I could stop if I wanted to rhayes.99001's Avatar
    2005-11
    New Jersey
    349
    Default Convert Layers to Standard
    I have a drawing that I need to convert all the layers to a new standard format.
    What is the best way to convert all the layers.???
    Is there a batch program to handle large files.?
    2002-09
    Madison, WI
    5,687
    Default Re: Convert Layers to Standard
    I"m sure if changing layer keys will work. You could try the layer translater if you know exactly what goes where. I've also seen a batch routine that our IT guy wrote using lisp and .txt file as that converted layer to layer name and color. I'm not sure how well it will work with the ADT objects. Just some ramblings.
  1. Export layers using 'aec uk cad standard' layers
    By Parkinson in forum Revit - In Practice
    Last Post: 2013-06-03, 02:50 AM
  2. Convert off layers to frozen layers
    By Tom.Weinstein.137333 in forum AutoCAD General
    Last Post: 2012-11-08, 05:04 PM
  3. Standard Layers
    By jenniferchavez in forum AutoCAD Civil 3D - General
    Last Post: 2007-09-27, 07:16 PM
  4. Standard layers and blocks
    By .chad in forum CAD Standards
    Last Post: 2006-10-20, 03:48 AM
  5. National CAD Standard Layers
    By rhayes.99001 in forum ACA General
    Last Post: 2006-09-30, 06:00 PM
