Summary: We should be able to customize file naming schemes for batch printing (to file) or exporting.
Description: Print dialog needs to support print file naming. It should allow us to use information stored in the sheet or view properties as well as the view title, and string constants to build-up a filename, similar to exporting image slices in Adobe ImageReady.
How Used: I'd set up the properties of each sheet, set up a standard file name scheme, and batch-print my 300 sheets, and go have coffee while the program runs, instead of manually naming each sheet as they go out, or sitting in windows explorer, re-naming each PDF after it arrives.
Feature Affinity: Views - Sheets
Submitted By: Jon Anunson on September 17, 2007
