Thread: View Ports and Walls
    2007-02
    Tucson, AZ
    60
    Default View Ports and Walls
    Here's the problem:
    My boss wants me to show the walls of the building in very light (.05mm) line weight on the plumbing and mechanical plans so that the plumbing and mechanical lines stand out better.
    I build only one model, and build all of my dimensions, plumbing, electrical, etc on that one model in different layers. Each of the different plans (floor plan, electrical, plumbing, etc) is just a sheet with a view port where I turn off the layers I don't need. Is it possible to make the same walls have different line weights for different view ports?
    We're not building these as ADT projects. It's just one file for all of the pieces.
    As always, thanks in advance for your help. One of these days I hope I can contribute something useful in return.
    Tim Glass
    Moderator arcadia_x27's Avatar
    2015-10
    The 'Mill,Moncton, NB, Canada
    516
    Default Re: View Ports and Walls
    You could accomplish this using display representations, setting up display reps for plumbing and mechanical. much like a reflected ceiling plan.
    Jason Goodwin
    Using ACA 2012
    2007-02
    Tucson, AZ
    60
    Arcadia,
    Thanks for responding. Unfortunately, that's totally foreign to me. Do you happen to have any links to tutorials?
    Thanks again,
    Tim
    2005-07
    2,356
    Quote Originally Posted by tim.glass View Post
    Arcadia,
    Thanks again,
    Tim
    ATP162 might be worth a look.
    2007-02
    Tucson, AZ
    60
    You guys are the best. Thanks as always.
  1. Ltscale for different View Ports
    By Borgster in forum AutoCAD General
    Last Post: 2011-11-01, 12:44 PM
  2. View ports won't plot
    By cocopli in forum AutoCAD Plotting
    Last Post: 2011-05-19, 11:05 AM
  3. view ports problem
    By mahaffeyesq in forum AutoCAD Tips & Tricks
    Last Post: 2008-05-26, 12:41 AM
  4. view ports
    By CHRISTINE.S in forum Revit Architecture - General
    Last Post: 2006-05-02, 07:19 PM
  5. pline view ports
    By cconner in forum AutoCAD General
    Last Post: 2004-06-16, 02:48 PM
