Results 1 to 10 of 10
Thread: Error When Opening a file???
    2007-01
    Dallas, TX
    57
    Angry Error When Opening a file???
    Maybe I'm missing something really basic here, but I'm using Revit Architecture 2008 and when I Double click on a .rvt file to open it, Revit launches, but I get an error that pops up saying
    "Windows cannot find '(the location of my file here).' Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search."
    Anybody else experienced this or have any idea how I might be able to fix it?
    Thanks!
    Kelli
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: Error When Opening a file???
    It happened to me a few times, just fire up Revit then open the file.
    AUGI Addict ws's Avatar
    Ambleside, Lake District, UK
    1,222
    Sounds like Windows has lost the file association with Revit...
    Generally to fix this sort of thing, in Windows explorer, right-click a Revit file and select Properties, click the Change button across from 'Opens with', and then, if not in the provided list, choose Select the program from a list and navigate to the Revit.exe folder.
    2015-11
    26
    I have the same problem and have never found a solution to it other than open Revit first and then double-click on the file.
    The program association is correct for *.rvt files so it's not that either. And it only happens on one or two machines in our studio so it's not something I can repeat uniformally on all machines in the same environment. I've wondered if this has anything to do with the "file locations" setting under the 'options' menu but the only thing I've changed there is the location (and name) of the template location.
    It's not a big deal but since I open almost all other files by simply double-clicking on them it is a hard habit to get out of. I wish I could figure out what is different about my particular Revit installation/configuration that is causing the problem.
    Thanks for any comments or solutions.
    Dean
    2005-03
    200
    Do you have both 2008 and 9.1 installed on your machine? I had this happen too, but the little problem dissapeared when I uninstalled 9.1.
    2015-11
    26
    Hmmm........ that's a good thought but unfortunately I only have Acad 2008 and Revit 2008 installed on this machine.
    It is an experience I've had at least since Revit 9 and maybe even R8.
    Thanks for the response. Hopefully I'll find a solution out there at some point........
    1,222
    If you are comfortable using Regedit (Start->Run->Regedit) have a look under
    HKEY_CLASSES_ROOT
    for the .rvt file association
    Mine says Revit.Project against the entry Default
    All AUGI, all the time gbrowne's Avatar
    2004-03
    Glasgow, Scotland
    579
    I get that all the time. So I open up Revit then file open the relevant job file, as suggested above. Quite scary the first time, eh?
    All AUGI, all the time clog boy's Avatar
    2006-12
    Probably near a PC.
    838
    I have Revit in the tartup folder for my PC, along with my e-mail program.
    From there I can browse to wherever I want.
    ...but yeah, no point in totally ignoring the issue. You can right-click a Revit file, and you'll find an option to select a program to open the file with (no idea what it's called in English since I use Windows in Dutch language). You then select the program as default application for that file type (check box) and the file type association should be restored.
    Windows system management 101
    LinkedIn
    "Too many variables!" - Mordin
    2015-11
    26
    Thing is, I know the file association is correct (even looking through the registry). When you get the message its not as if Revit isn't trying to open at the same time. It is and does open but gets stuck because you get the error message in your "My Computer" window. After you go back to the "My Computer" window the error message is there (not in Revit) and once closed - it's the only option available - Revit is open and functional but it just doesn't have the file open that you double-clicked on. If you then double click on it again it will open just fine.
    Also, once you have operated Revit using the above method and closed it you are able to double click on the file (or any Revit file) and have the file open normally. It seems to happen only after the 'first' time you try opening Revit (after having booted up or rebooted).
    Thanks for your thoughts. Funny thing is it sounds like this happens to quite a few users and most people just ignore it. I wonder if the factory has been working on this?
    Dean
  1. Error when opening a file with SP 03
    By S.Agnew in forum Inventor View - General
    Last Post: 2010-05-04, 02:47 PM
  2. Error when opening a .dxf file...
    By terynl in forum ACA General
    Last Post: 2009-08-04, 12:55 PM
  3. Error While opening DWF file
    By satish in forum Design Review - General
    Last Post: 2009-03-02, 12:38 PM
  4. Replies: 3
    Last Post: 2008-07-28, 07:31 AM
  5. Error when opening file
    By pogibob in forum Revit Architecture - General
    Last Post: 2007-03-30, 06:30 PM
