Thread: Civil 3D as Autocad Start up in Map Display Manager
    2007-03
    68
    Question Civil 3D as Autocad Start up in Map Display Manager
    I wonder if there is a quick way to start Autocad from my C3D installation without the opening of the map display manager pallet . The first thing I do when I want vanilla autocad is close this pallet. Is there any start up keys or config files I could change? If not...it isn't that tough to deal with. Thanks for any tips. I am using 2008 sp1
    Civil Engineering Moderator MHultgren's Avatar
    Indy West (Not West Indies)
    1,447
    Default Re: Civil 3D as Autocad Start up in Map Display Manager
    Hi CD,
    If you go to your Map pulldown - Options there is a checkbox to turn off the Map Dialog. You can uncheck that box, then save the profile to a new name and set that profile in your Icon properties.
    2007-03
    68
    Mark,
    Once again, I thank you.
    Coon 3 Dog
  1. ME433-1: To Display or Not to Display: Understanding the Display Manager in AutoCAD® MEP
    By Autodesk University in forum MEP Design and Engineering
    Last Post: 2023-08-14, 03:51 PM
  2. GS314-1L: Stylize It: The AutoCAD Map 3D Display Manager
    By Autodesk University in forum Planning and GIS
    Last Post: 2014-12-01, 03:35 AM
  3. MP318-2: Display System for AutoCAD MEP: A Detailed Dive Into Display Manager
    Last Post: 2014-12-01, 03:24 AM
  4. 2012: AutoCAD MEP Display manager nodes and 3D objects
    By dncnh2o3930142 in forum AMEP General
    Last Post: 2012-12-06, 10:58 PM
  5. AutoCAD 2005 - Layer Manager does not display
    By pford in forum AutoCAD General
    Last Post: 2007-05-30, 01:46 PM
