Thread: Two parts on the same .idw
    2004-08
    27
    Default Two parts on the same .idw
    I have made an assembly of numerous aluminum panels and have also placed an aluminum angle with constraints on each of the wall panels. I need for this aluminum angle to appear in the idw so that the manufacturer knows where to place it.
    Thanks in advance.
    Casey
    Williamsport, PA
    641
    Default Re: Two parts on the same .idw
    I've read this 3 or 4 times. You tell us what you've done but I don't see a question?
    Can you expand a bit? Doing an assembly drawing idw of an iam should be easy. You can also place more than one part view from different parts in an idw. Maybe post the files?
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    AU 2007 Avatech Altogether Smarter Inventor On-line Challenge 1st Place
    Autodesk Inventor Certified Expert
    Certified SolidWorks Professional
    Williamsport, PA
    2004-08
    27
    I have figured out what I need to do. I need to make each panel an assembly and place the aluminum angle and then it will show up on each of my idw's.
  1. Parts From the CC Display Modified Lengths in Parts List
    Last Post: 2012-12-19, 04:16 AM
  2. 2012: ICOPY, supressing parts and constraining standart parts
    By damper1839380 in forum Inventor - General
    Last Post: 2011-12-21, 03:33 PM
  3. Parts List Styles and Extents available in Parts List
    Last Post: 2009-06-19, 02:13 PM
  4. Adding Metric Parts in Parts List?
    By Keefe_Lee_G-and-O in forum AutoCAD Civil 3D - Pipes
    Last Post: 2008-08-19, 12:54 PM
  5. Mirror Assembly Parts as True Parts
    Last Post: 2006-07-09, 04:03 AM
