Results 1 to 8 of 8
Thread: Does anyone have a method for creating "claymation" or "chipboard" style renderings?
    2015-12
    76
    Question Does anyone have a method for creating "claymation" or "chipboard" style renderings?
    Does anyone have a method for creating "claymation" or "chipboard" style renderings? Using preferrably REVIT standalone or Viz Link method?
    AUGI Addict cdatechguy's Avatar
    2006-10
    CdA, ID
    1,533
    Default Re: Does anyone have a method for creating "claymation" or "chipboard" style renderings?
    Change your materials to one color... I do that time to time with ArchiCAD as well....
    Michael "MP" Patrick
    "I only drink :coffee: until it's acceptable to drink :beer: or :whiskey: or :wine:"
    I could stop if I wanted to Phil Read's Avatar
    2003-05
    Charlotte, NC
    398
    Rename the default "_accurender.mlib" file. Revit won't be able to locate material assignments for renderings. The file is usually at the location:
    C:\Documents and Settings\All Users\Application Data\Autodesk\RAC 2008\Rendering\AccuRenderRedist\support\_accurender.mlib
    This assigns a white, matte material during rendering - while keeping shaded material assignments and surface patterns intact.
    Just rename the mlib file back to "_accurender.mlib" when you want to see or assign material assignments.
    Example image attached.
    All the best.
    Phil
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    if you can run an ink & paint render in revit you might want to look into that. i know max supported it but i dont know about viz.
    The CADSmith Chad Smith's Avatar
    2003-05
    Brisbane, Australia
    1,731
    When I was doing it in VIZ, I started off with setting all my materials in the scene to an almost white colour. Then for the lighting I used a light dome that had some 93 low level lights scattered over it. This gave it a reasonable model look. I then added colour to the scene.
    But, this was before radiosity was introduced which I am still yet to play with.
    These are some of the results I got. All models were modelled in Architectural Desktop 3.0.
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,535
    It's a little roundabout, but there is a free renderer called indigo (indigorenderer.com) that has an exporter from 3D max and sketchup and it will do a single tone rendering very nicely (it's an unbiased renderer). You can pick what material to apply to the whole model (white tone, grey tone, beige clay tone, whatever).
    I export the Revit model to dwg and then put that in sketchup and render from there. Like I said, a little round about, but free and with good results.
    2015-12
    76
    Talking Re: Does anyone have a method for creating "claymation" or "chipboard" style renderings?
    Guys.....these are great techniques!!!!!....I will try them out. It looks like I will have to export to dwg one way or another for the best results. I really appreciate the response.
    100 Club Fred Blome's Avatar
    2003-05
    Palo Alto, California
    143
    SU Podium for sketchup does something similar, by not assigning materials.
  1. Replies: 13
    Last Post: 2015-01-26, 01:35 PM
  2. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  3. Replies: 5
    Last Post: 2009-04-17, 10:10 AM
  4. ENTIDADES EN ALIGNMENT COMO "FIXED", "FLOTING" y "FREE"
    By cadia in forum AutoCAD Civil 3D - General
    Last Post: 2009-02-01, 04:21 AM
  5. Replies: 1
    Last Post: 2006-06-13, 06:36 PM
