Thread: Fence Lintype Spacing...
    2004-12
    California
    283
    Default Fence Lintype Spacing...
    I have found a few versions of a chain link fence linetype that work great with one exception.....the spacing. Is there a way to accurately get the X in the chain link to space at 10'?
    Below is the linetype I found and am using....
    *FENCE, Fence ---- X ---- X ---- X ---- X ---- X ----
    A,.5,-.025,[TRACK1,ltypeshp,r=135,s=.08],0,[TRACK1,ltypeshp,r=45,s=.08],-.025,.5
    Thanks!
    Earth
    9,815
    Default Re: Fence Lintype Spacing...
    What do you mean to "space at 10'"?
    Set your LTSCALE to 1.0, then the numbers in the LIN file are real-world. Adjust them as needed.
    R.K. McSwain | CAD Panacea |
    2004-11
    Altoona,PA
    301
    We can get the linetype to be correct for ONE ltscale. Then you will need to do object overrides to make it correct for the other ltscales.
    What ltscale do you use most often?
    Terry
  1. Replies: 0
    Last Post: 2014-08-11, 07:32 PM
  2. Louvered Fence( Line Based Family), Help With controlling spacing.
    By luna.j.francisco741580 in forum Revit Architecture - Families
    Last Post: 2012-10-03, 04:39 PM
  3. Fence - LISP to pick a pre determined fence line?
    By EngME in forum AutoCAD General
    Last Post: 2011-10-31, 08:21 PM
  4. FENCE ??
    By shaunamorain in forum Revit Architecture - General
    Last Post: 2007-01-12, 04:54 PM
  5. Layers keep on defaulting to "Hidden" lintype!
    By Cosmic Traveller in forum AutoCAD Mechanical - General
    Last Post: 2006-02-17, 04:30 PM
