Rocky,
Could you direct me to a link which explains how to add custom materials (such as AISI 52100) into inventors material properties. By the way.... Chad say's "Hey"
Rocky,
Eddie;
Can't find the tutorial I was looking for right away. To get the material properties, go to www.matweb.com.
Try these links........
http://usa.autodesk.com/adsk/servlet...linkID=9242018
FYI........
http://www.mcadforums.com/forums/viewforum.php?f=41
http://www.avat.com/training/elearni...ion.asp?sgid=4
I'll keep looking.
One way to do this is by opening your part template (ie C:\Program Files\Autodesk\Inventor 2008\Templates\standard.ipt) Then under Format - Style and Standards Editor select materials. Select Default and then click the New... button on the right hand panel. Give it a name, fill out the information and next time you use this template it will be available for use.
We make brake shoes, so I have lots of custom materials for our friction materials. I add these to the template as stated before. I also have several templates, one for the friction materials, another for steel parts, etc. That way I don't have to wade through the whole list to select the material I want.
Tim
