Thread: Hydrology and Hydraulics
    Wish List Administration
    2007-08
    434
    Default Hydrology and Hydraulics
    Summary: I would like to see the hydraulic design module (improved from LDD) back into the program that will allow storm sewer design and detention pond design.
    Description: I would like to see the hydraulic design module (improved from LDD) back into the program that will allow storm sewer design and detnetion pond design. The results could then be used with the current pond grading features and pipe tools to layout the pond and storm sewer design.
    How Used: Design Storm sewers and detention ponds all with one program.
    Feature Affinity: Pipes
    Submitted By: Rick Carle on August 23, 2007
    2003-03
    Default Re: Hydrology and Hydraulics
    I think it would be great to include Sanitary Sewer modeling too.
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    The ability to define a catchment area by picked point.
    This command would allow me to select a point(s), for example catchbasins around my site and have the program tell me what drain's to that point based on a finished grade surface. You would have to be able to select multiple locations at once to correctly determine catchment area because the upstream catchbasin would serve as a cutoff point for the downstream catchbasins. If only one point was selected it would show overland flow route as everything upstream from that point would be included in the area.
    (Submitted by: Mike Smith)
    2002-04
    Colorado
    2,020
    I would like to be able to calculate storm pipe quantities.
    I use the storm pipe calculations to size the pipe very often. I would like to stay in Civil 3D.
    (Submitted by: Derek Miller)
  1. Civil Design - Hydrology/Hydraulics Tutorial
    By iepms in forum Civil 3D - Civil Design Companion - General
    Last Post: 2020-10-11, 11:33 AM
  2. Hydrology in Civil 3D?
    By jpaulsen in forum AutoCAD Civil 3D - General
    Last Post: 2007-11-19, 08:33 PM
  3. Water System Hydraulics
    Last Post: 2007-09-12, 02:24 PM
  4. Hydrology and Hydraulics
    By vbossi in forum Civil 3D Wish List
    Last Post: 2007-08-24, 04:53 PM
  5. Civil Design - Hydrology/Hydraulics Tutorial
    By iepms in forum Civil 3D - Civil Design Companion - Wish List (Closed)
    Last Post: 2005-03-21, 09:06 AM
