Thread: Electrical Symbology
    2005-12
    89
    Default Electrical Symbology
    Good morning,
    Does anyone have a Block for a 4-wire Terminal Block or know where I might get one? If so would you be willing to send it to me?
    Thank you
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,124
    Default Re: Electrical Symbology
    Have you tried a search? Or have you tried this post (RE: Interior Design Symbols for Plans)? There may be something in there that should point you in the right direction.
    Good Luck.
    All AUGI, all the time Richard.Kent's Avatar
    2001-01
    Albuquerque, NM, USA
    622
    Quote Originally Posted by boyerd View Post
    Good morning,
    Thank you
    Here is one I drew a while ago, I assumed you needed the side view. If you need the top view it will be easy enough to draw from what I am sending you.
  1. 2012: 2D Symbology
    By ThatBIMGuy in forum Revit MEP - General
    Last Post: 2011-09-08, 04:19 PM
  2. Ductwork Set-up & Set down Symbology
    By burnsrich in forum Revit MEP - General
    Last Post: 2010-01-05, 12:25 PM
  3. Tag Symbology that changes per Use
    By Mike_Maloney in forum Revit Architecture - General
    Last Post: 2009-12-09, 04:09 PM
  4. Electrical Symbology
    By boyerd in forum AutoCAD Tips & Tricks
    Last Post: 2007-10-01, 05:22 PM
  5. Map Symbology
    By gary_pritchard in forum AutoCAD Map 3D - General
    Last Post: 2006-02-15, 08:30 PM
