I was asked to help solve an issue on a Revit project in our office. When looking at the floor plans it appears that the view is somehow slightly off axis. In other words when looking at vertical objects such as steel columns you see the location the column is cut based on the cut plane then as you hover over it you see it going off at a slight angle to the extent defined by the view depth. My first thought of course was that the column was somehow not vertical and was tilted. However when looking at sections cut from the floor plan the column does appear to be exactly vertical.
I know that sections can be rotated and aligned to non orthagonal positions but is that also possible for a floor plan?
I tried to research this issue and found a lot of discussion about origin issues. I did discover that this revit model was built thousands of feet off of the origin. Could this be playing a role in the floor plan view being off axis?
Any thoughts on this would be appreciated.
Thanks
