Thread: Styles and Standards Editor - Dimensions
    2004-02
    Default Styles and Standards Editor - Dimensions
    I just upgraded to Inventor 9, and I'm having some problems figuring out how to change the dimensioning standard on drawings. The defalt is ANSI, and I want to use ANSI FRACTION as the defalt. I've tried a lot of different things but dimensions are alway created with ANSI formating. It is far too time consuming to change each dimension individually. Does anyone know how I can change the drawing dimension standard to ANSI FRACTION
    Erin
    Member rosterreicher's Avatar
    2004-06
    Indiana
    39
    Default Re: Styles and Standards Editor - Dimensions
    In the styles editor, There is an item in the left column called object defaults. Click that and then click the standard (probably ANSI) then back in the right side find the type of dimension and change the style to the fractional style you want.
    Hope that helps .
  1. styles and Standard editor
    By burninin1 in forum Inventor - General
    Last Post: 2010-10-12, 08:48 PM
  2. Why are line styles not available in the family editor
    By jkipfer in forum Revit Architecture - General
    Last Post: 2010-03-25, 02:41 PM
  3. XML editor for Inventor Styles?
    By jonathan.landeros in forum Inventor - General
    Last Post: 2007-06-21, 11:18 PM
  4. External CAD Standards Editor
    Last Post: 2006-11-08, 08:12 PM
  5. Standards Checker for Styles
    By BCrouse in forum ACA Wish List
    Last Post: 2005-10-19, 12:23 AM
