Hi Chris
Hope this helps
Sub Example_SelectAtPoint()
' This example adds objects to a selection set by identifying a point.
' At first all objects at the point are added to the selection set. Then
' only circle objects at the point are added to the selection set.
' Create the selection set
Dim ssetObj As AcadSelectionSet
Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SSET1")
' Add to the selection set all the objects that lie at point(6.8,9.4,0)
Dim point(0 To 2) As Double
point(0) = 6.8: point(1) = 9.4: point(2) = 0
ssetObj.SelectAtPoint point
' Add to the selection set all the Circles that lie at point (6.8,9.4,0)
Dim gpCode(0) As Integer
Dim dataValue(0) As Variant
gpCode(0) = 0
dataValue(0) = "Circle"
Dim groupCode As Variant, dataCode As Variant
groupCode = gpCode
dataCode = dataValue
ssetObj.SelectAtPoint point, groupCode, dataCode
End Sub
You can change "Circle" to any object you are trying to select
Brent
