Thread: Column under beam
    2007-02
    75
    Default Column under beam
    More options on the way how beams and columns are connected. Par example the possibility to set a column automaticly under the beam.
    100 Club Steve Mintz's Avatar
    2006-03
    San Diego, CA
    169
    Default Re: Column under beam
    You can currently attach the top of a column to the bottom of a beam.
    2007-02
    75
    Yes I know that, but it's better automaticly, cause by a large building it cost a lot of time.
    2006-03
    87
    How can you do this? Whenever I try it tells me that the beam and column are already joined, and that I'm not allowed to attach them. Do I have to go and manually un-join them all, just so I can come back and attach? And won't that make things difficult if any of this ever moves?
  1. Beam to column ???
    By johnthao714 in forum Revit Structure - General
    Last Post: 2010-06-14, 12:10 PM
  2. COLUMN TO BEAM GAP
    By clintonc in forum Revit Structure - General
    Last Post: 2010-06-03, 07:10 PM
  3. Quickest way to unjoin beam and column and attach column bottom of beam.
    By scowsert in forum Revit Structure - General
    Last Post: 2008-04-24, 03:54 AM
  4. beam / column tie sets
    By Peter Davies in forum Revit Structure - Wish List
    Last Post: 2007-09-17, 12:35 AM
  5. Column & Beam Schedules
    By barathd in forum Revit Architecture - General
    Last Post: 2005-08-10, 03:58 PM
