Thread: Disable Property Data Dialog during tag insertion
    2006-12
    Big "D"
    3,711
    Default Disable Property Data Dialog during tag insertion
    Ever have to insert a lot of tags? Tired of seeing the edit property set data worksheet pop up for every tag insertion? Well, just turn it off! Go to options, AEC content tab, and clear Display Edit Property Data Dialog During Tag Insertion, and click OK. If you need to edit a tag, it can still be done in properties.
    2003-10
    San Francisco CA
    1,190
    Default Re: Disable Property Data Dialog during tag insertion
    Thanks Dan. That will help reduce my "annoyance factor" when inserting tags. Good catch.
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    2006-12
    Big "D"
    3,711
    Quote Originally Posted by stelthorst View Post
    Glad I could help. So that makes it Dan 2, Scott 25,728. I have a little catching up to do!
    2003-10
    San Francisco CA
    1,190
    Quote Originally Posted by dzatto View Post
    Hi Dan,
    Thanks for the compliment. Your not giving yourself enough credit though I've seen you make a bunch of helpful and informative posts.
    Keep up the good work.
    Scott Telthorst
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Finally, a tip worthy of being in the tips and tricks section. Thanks! That's worth at least one at AU.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
  1. Set Insertion Point Property on Tool Palette
    Last Post: 2010-03-26, 06:34 PM
  2. Object data from entity to FDO Feature data property
    By vlee in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2009-04-09, 04:59 PM
  3. Disable Civil object data in map 2006
    By jessebelcher in forum AutoCAD Map 3D - General
    Last Post: 2005-12-09, 04:18 AM
  4. xref property change via dialog
    By BIGGEORGE in forum AutoLISP
    Last Post: 2005-08-10, 09:05 PM
  5. Screening property in layer dialog
    By along.71225 in forum AutoCAD Wish List
    Last Post: 2004-07-06, 06:14 PM
