Thread: Selecting a list of folders and removing all ".bak", ".err", ".xlg" & "plot.log" files from folders & sub folders
    2005-08
    378
    Cool Selecting a list of folders and removing all ".bak", ".err", ".xlg" & "plot.log" files from folders & sub folders
    Guys,
    Is it possible to be able to select multiple folders in a drive and have all ".bak", ".err", ".xlg" & "plot.log" files removed from not only those files but also any sub folders using lisp ?
    Does anyone have anything like this they would share ?
    Stephen
    2007-08
    201
    Default Re: Selecting a list of folders and removing all ".bak", ".err", ".xlg" & "plot.log" files from folders & sub folders
    Hi,
    This one doesn't allow to select multiple folders at once, but it clean up all the sub folders of the specified one.
    ;| GetFolders
    ;;; Returns the list of all sub folders of the specified folder or drive (path)
    ;; Example
    ;; (GetFolders "C:\\Program Files\\AutoCAD 2007\\Help")
    ;; ("C:\\Program Files\\AutoCAD 2007\\Help\\buildyourworld"
         "C:\\Program Files\\AutoCAD 2007\\Help\\Tutorials"
         "C:\\Program Files\\AutoCAD 2007\\Help\\Tutorials\\createTransmittal"
         "C:\\Program Files\\AutoCAD 2007\\Help\\Tutorials\\crossReference"
         "C:\\Program Files\\AutoCAD 2007\\Help\\Tutorials\\crossReference\\Models"
         "C:\\Program Files\\AutoCAD 2007\\Help\\Tutorials\\PlaceView"
         "C:\\Program Files\\AutoCAD 2007\\Help\\Tutorials\\PlaceView\\Models"
         "C:\\Program Files\\AutoCAD 2007\\Help\\Tutorials\\PublishSheetSet"
         "C:\\Program Files\\AutoCAD 2007\\Help\\Tutorials\\sheetListTable"
         "C:\\Program Files\\AutoCAD 2007\\Help\\Tutorials\\Symbol Libraries"
         "C:\\Program Files\\AutoCAD 2007\\Help\\Tutorials\\ViewSheetSet"
         "C:\\Program Files\\AutoCAD 2007\\Help\\Tutorials\\ViewSheetSet\\xrefs")
    (defun GetFolders (path / l c)
      (if (setq l (vl-directory-files path nil -1))
        (apply 'append
    	   (mapcar '(lambda (x)
    		      (cons (setq c (strcat path "\\" x)) (GetFolders c))
    		   (vl-remove "." (vl-remove ".." l))
    ;; str2lst
    ;; Parses a string in a sub string list
    ;; Arguments
    ;; str : the string to be parsed
    ;; sep : the separator
    ;; Examples
    ;; (str2lst "a b c" " ") -> ("a" "b" "c")
    ;; (str2lst "1,2,3" ",") -> ("1" "2" "3")
    ;; (mapcar 'read (str2lst "1,2,3" ",")) -> (1 2 3)
    (defun str2lst (str sep / pos)
      (if (setq pos (vl-string-position (ascii sep) str))
        (cons (substr str 1 pos)
    	  (str2lst (substr str (+ (strlen sep) pos 1)) sep)
        (list str)
    ;; CleanFolder
    ;; Deletes all files with specified extensions in the specified folder and sub folders
    (defun c:cleanfolder (/ path exts cnt)
      (and
        (or
    	  (setq
    	    path (getstring T "\nEnter the folder path <Dialog box>: ")
          (setq path
    	     (vl-filename-directory
    	       (getfiled "Select a file in the folder to be cleaned"
        (setq exts (getstring "\nEnter the extensions (bak,err,log,...): "))
        (setq cnt 0)
        (mapcar
          '(lambda (fold)
    	 (mapcar '(lambda (ext)
    		    (mapcar '(lambda (file)
    			       (vl-file-delete
    				 (strcat fold "\\" file)
    			       (setq cnt (1+ cnt))
    			    (vl-directory-files fold (strcat "*." ext))
    		 (str2lst exts ",")
          (cons path (getfolders path))
      (princ (strcat "\n\t" (itoa cnt) " files deleted"))
    2007-05
    7
    I run the following batch file nightly using scheduler to delete unwanted files prior to our scheduled tape backup.
    del F:\*.gid /s /q /f
    del F:\*.bak /s /q /f
    del F:\*.dmp /s /q /f
    del F:\*.bp3 /s /q /f
    del F:\*.sv$ /s /q /f
    del F:\*.err /s /q /f
    del F:\*.bk1 /s /q /f
    2007-08
    201
    Here's a more convivial version, using dialog boxes
    (comments aren't translated)
    ;;; GetFolders
    ;;; Retourne la liste de tous les sous-dossiers du dossier (ou disque) spécifié (chemin)
        (apply 'append
    ;; str2lst
    ;; Transforme un chaine avec séparateur en liste de chaines
    ;; Arguments
    ;; str : la chaine à transformer en liste
    ;; sep : le séparateur
    ;; Exemples
        (list str)
    ;;; InputBox Ouvre une boite de dialogue pour récupérer une valeur (string)
    (defun InputBox	(Titre Message Defaut / *acad* users1 valeur)
      (setq	*acad* (vlax-get-acad-object)
    	users1 (getvar "users1")
      (acad-push-dbmod)
      (vla-eval *acad*
    	    (strcat "ThisDrawing.SetVariable \"USERS1\","
    		    "InputBox (\""	   Message
    		    "\", \""		   Titre
    		    "\", \""		   Defaut
      (setq valeur (getvar "users1"))
      (setvar "users1" users1)
      (acad-pop-dbmod)
      valeur
    ;;; MsgBox  -Patrick_35-
    ;;; Ouvre une boite de dialogue pour récupérer la réponse à une question
    (defun MsgBox (Titre Boutons Message Time / Reponse WshShell)
      (setq WshShell (vlax-create-object "WScript.Shell"))
      (setq	Reponse	(vlax-invoke
    		  WshShell
    		  'Popup
    		  Message
    		  Time
    		  Titre
    		  (itoa Boutons)
      (vlax-release-object WshShell)
      Reponse
    ;;; DirBox -Patrick_35-
    (defun DirBox (Message Chemin Drapeau / rep sh)
      (vl-load-com)
      (setq sh (vlax-create-object "Shell.Application"))
      (if (setq
    	rep (vlax-invoke sh 'browseforfolder 0 Message Drapeau Chemin)
        (setq rep (vlax-get-property (vlax-get-property rep 'self) 'path))
        (setq rep nil)
      (vlax-release-object sh)
      rep
    ;; CleanFolder (gile)
    ;; Supprime du dossier et de ses sous dossier tous les fichiers
    ;; aux formats spécifiées (séparateur = virgule).
      (vl-load-com)
      (and
        (setq path (dirbox "Select the folder" "" 512))
    	(setq exts
    	       (inputbox
    		 "Cleanfolder"
    		 "Enter the extensions of the files to be deleted
    	     \n(separator = comma)"
        (= 6
           (msgbox
    	 "CleanFolder"
    	 52
    	 (strcat "Do you realy want to delete all the files\n"
    		 exts
    		 "\nfrom the folder\n"
    		 path
    	 10
        (setq cnt 0)
        (mapcar
          '(lambda (fold)
    	 (mapcar
    	   '(lambda (ext)
    			 (vl-file-delete
    			 (setq cnt (1+ cnt))
    		      (vl-directory-files
    			fold
    			(strcat	"*."
    				(vl-string-left-trim
    				  (vl-string-left-trim "*" ext)
    	   (str2lst exts ",")
        (alert (strcat (itoa cnt) " deleted files"))
    2001-10
    Defragging the internets.
    343
    Quote Originally Posted by bob.vandusen View Post
    Thanks for the batch routine. I had one for creating a text file to show our *plt files.
    If you want a list you can change it to:
    Dir F:\*.gid *.bak *.dmp *.bp3 *.sv$ *.err *.bk1 /s /q > F_Drive_Junk.txt
    Chris
    2009-04
    hello everybody!
  1. Replies: 0
  2. ENTIDADES EN ALIGNMENT COMO "FIXED", "FLOTING" y "FREE"
    By cadia in forum Español - AutoCAD Civil 3D
  3. Replies: 3
    Last Post: 2007-10-23, 09:06 PM
  4. Replies: 8
    Last Post: 2007-04-04, 12:39 PM
  5. Replies: 1
    Last Post: 2006-06-13, 06:36 PM
