I have the current Revit/RAM link for Revit Structure 2008, and was able to export several very small simple test structures from Revit into RAM with no problems.
Am now trying to do the same on a three story structural steel framed dormitory structure. No slopes or anything fancy that RAM couldnt handle. Doesnt even have barjoists. Problem is, it looks like the Revit analytical model is completely messed up and results in about a thousand "beam not supported" errors in RAM. It looks like many of the Revit analytical beam nodes arent connecting to the column nodes OR they connect, but are several inches off from physical model.
Is there any way to easily correct all of these errors in Revit? How do I prevent this in the future? Any other ideas?
If I look at the 2nd floor analytical view, I can see the beam connection nodes, select them, but it doesnt snap them to the columns. I can get it close, but not snapped. If you dont know RAM, even if the beam/column connection is 0.001" off, it won't work. One would think the analytical model would snap to the column just like the physical model.
