Results 1 to 10 of 10
Thread: How to Write LISP Routine Drawing Associative Hatch Pattern?
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Default How to Write LISP Routine Drawing Associative Hatch Pattern?
    Hi ALL,
    Every time I write a hatch founction, the LISP draws a nonassociative hatch pattern.
    How to get it associating with its boundaries?
    Thanks
    Ke
    Blue Springs, MO
    658
    Default Re: How to Write LISP Routine Drawing Associative Hatch Pattern?
    You could alway use the HPASSOC system variable in your routine to ensure your hatch will alway be associative.
    2006-04
    1,160
    Quote Originally Posted by jmctamney View Post
    I checked my drawing & my code again.
    HPASSOC on my drawing & code has already been set to 1.
    I can't see the hatch is associative.
    The following was subtracted from my code:
    (setvar "HPASSOC" 1)
    (command "_hatch" "MUDST" 20 "0" ent1 "")
    2006-11
    UTAH
    135
    Quote Originally Posted by ke.li View Post
    Change your hatch command to this:
    (command "._-HATCH" "P" "MUDST" 20 "0" "A" "A" "Y" "" "S" ent1 "" "")
    This forces the command-line version of hatch to run, where you can specify whether or not it should be associative. The usual lisp version of hatch is extremely old and therefore doesn't give you the option.
    Cheers!
    2006-04
    1,160
    Quote Originally Posted by Mike_R View Post
    Cheers!
    It doesn't work on my 2005 Mechanical as the command prompt returns the following:
    Command: ._-HATCH Unknown command "-HATCH". Press F1 for help.
    Command: P Unknown command "P". Press F1 for help.
    Command: MUDST Unknown command "MUDST". Press F1 for help.
    Command: 20
    Command: 0 Unknown command "0". Press F1 for help.
    Command: A Unknown command "A". Press F1 for help.
    Command: Y Unknown command "Y". Press F1 for help.
    Command: SD Unknown command "SD". Press F1 for help.
    Command: S Unknown command "S". Press F1 for help.
    Command: <Entity name: 7ED79A58>
    NOTE: "SD" is my routine command.
    And your suggestion may not work for the old versions, ie 2005 Mechanical.
    I tried to understand what you said & did a test:
    Firstly, I set HPASSOC to 1 in command line.
    Then enter "-H" and select a rectangle. It does a hatch.
    If I check the hatch it will tell me it is a nonassociative hatch!
    Now, I know the one I did below can only create a nonassociative hatch.
    Is it what you mean?
    2006-11
    UTAH
    135
    Okay, as it turns out, "-HATCH" apparently isn't recognizable in 2005, so this time I checked with 2002 and realized that it has to be "._-BHATCH"... So change it to this:
    (command "._-BHATCH" "P" "MUDST" 20 "0" "A" "A" "Y" "" "S" ent1 "" "")
    Replace it with that and it should work this time. Sorry about that.
    Cheers!
    2006-04
    1,160
    Cheers!
    It's Great! Thank you very much!
    Thing that I wish to learn is the reason you use "." and "_" at the front of the command.
    Thanks again, Mike
    Ke
    2006-11
    UTAH
    135
    The "_" is to tell AutoCAD to translate the following command into whatever the local language of the user is. Most of the time it's in English, but sometimes it's Polish, German, etc.
    The "." is to tell AutoCAD to use the built-in version of the command, even if it's been undefined previously. It just insures that no other customization gets in the way of the program running as it should.
    2006-04
    1,160
    Thanks for your help.
    2006-11
    UTAH
    135
    Anytime ke.
  1. 2013: LISP Routine for adding Coords / Leader / Northing + Easting to Drawing
    By Wayne.Tappe in forum AutoCAD General
    Last Post: 2013-12-11, 02:10 PM
  2. Replies: 2
    Last Post: 2012-04-02, 02:33 PM
  3. Replies: 10
    Last Post: 2009-06-04, 03:53 PM
  4. Selecting Associative Hatch also selects Hatch Boundary
    By gadjet in forum AutoCAD General
    Last Post: 2006-08-11, 07:14 PM
  5. Write a LISP routine to enhance the revcloud command
    By melissa.j.seidel in forum AutoLISP
    Last Post: 2005-11-14, 06:08 PM
