Summary: To be able to generate a new space, then copy all of the property set data from an existing similar space.
Description: I would like to be able to generate a space, then open another file where the space already exists (different project) and somehow copy the property set data to the new space.
How Used: In a new project, you could generate the space, but the property set data is all --. Nothing is filled in yet as far as wall textures, flooring, cove base, etc. If I already have a similar space in another project, I could somehow copy the data from one space to another. The only 2 options I have now are to either:
1. Type all the information again or
2. Copy the space, then manually edit the boundaries to make it fit the new space, thereby making the auto generate command useless.
