This is an old one. Everything is modeled in MAX and rendered with MR. Had a very short deadline on this one and i'm planning on going back and fixing some of the obvious issues!
Really Nice
I Like this kind of details
Cheers
Thanks...i wanted to put fish in there but the bosses said it would have been too much!
Nice job. I spy one thing that needs to get fixed.
Someone is using some jedi powers to levitate some of the rock bed near the concrete wall...
Okay, I've been trying to replicate this for a while now...
Two questions:
1.) How do you do your translucent water? It's sweet -- much better than I've done. I've done clear water fairly well, with the refraction, but you've got such a nice blue-ish smooth translucency going on...
2.) How'd you get those nice "kind-of-smooth" sides on the water? That's not noise (that's the top right?), so how'd you do it?
Spill the beans Dwayne...
For the water i used geometry for most of the water turbulence. You can basically strat with a box and then use something like a poly select or a volume select to the top polys and then start adding modifiers to effect it. Using the poly selects just tell max not to touch the sides and only effect the top....though you can see some of the effects of the mapping coming through on the sides.
Okay, little errors or not, I really like this. I like the little details, like the plants coming up near the piers, but I really like the look of the water -- it looks almost dirty, a little thicker than drinking water. I've replicated the physical geometry of the water, but can't get that transluscence. How the water is clearer where it's shallower (from the pov), and more opaque as it gets deeper is really interesting, and something I've failed to reproduce. Can you explain how you did this?
How ironic. We just got a request to do something similar for a client. And they are asking for a specific fish! I'll have to share once we get some images...
Yeah....its ironic....i've just been asked to do another one as well. I'll post some stuff when i can!
