Thread: Cursor Disappearing act
    2005-10
    5
    Default Cursor Disappearing act
    I recently upgraded to 2008 and I have this problem after certain commands. For example with erase, I start the command and click the object and hit enter (right click) and my cursor disappears. It is rather annoying because you have to "wiggle" the mouse whenever you complete the command. I also noticed while a command is active and I move the mouse the title bar will flicker. I made sure I have the latest display drivers and my windows updates have all been installed. My monitor is a 20.1" LCD flat panel hooked up through DVI. I am running Windows XP SP2.
    My specs:
    2.13 GHz Core2 Duo
    2 GB ram
    NVIDIA Quadro FX 1500
    Please, I need help before I go insane
    2005-10
    5
    Default Re: Cursor Disappearing act
    Anybody have any suggestions?
    All AUGI, all the time CADDmanVA's Avatar
    2006-12
    New Orleans, LA
    881
    When did you update the drivers on your video card to the newest version? Maybe try rolling back to an older version, I had to do that myself. Another thought, try re-running the performance tuner.
    2002-05
    4
    Hi,
    I had this happening in a drawing that had come from another company. Finally figured out why ... the Layout plot scale was 1:0.001 and the Snap size was set to 10m, so my cursor was snapping somewhere off in space! Hence, the darn thing was disappearing. Check your snaps and your plot scale.
    Cheers,
    -monkey5672
    I could stop if I wanted to jarod.tulanowski's Avatar
    2001-12
    Columbus, Ohio
    313
    I have the same darn problem. talk about an issue. The mouse wiggle has become sort of a nervous twitch now haha. (almost like the old three or four hits of the escape key I use to do just to make sure I was out of a command) Is there anything graphic driven that would cause this?
    P.S. this is happening on multiple computers throughout the office.
    2006-12
    New Orleans, LA
    881
    Quote Originally Posted by jarod.tulanowski View Post
    I have the same darn problem. talk about an issue. The mouse wiggle has become sort of a nervous twitch now haha. (almost like the old three or four hits of the escape key I use to do just to make sure I was out of a command)...
    HA! Funny you mention that. I still hit escape about four times.
  1. Disappearing cursor and pick box
    By jrb63 in forum ACA General
    Last Post: 2012-09-28, 02:34 PM
  2. Disappearing Cursor (Layer Colors)
    By tl.140546 in forum AutoCAD LT - General
    Last Post: 2007-10-10, 04:58 PM
  3. Cursor Question
    By janunson in forum Revit Architecture - General
    Last Post: 2007-01-17, 11:19 PM
  4. cursor cannot be seen
    By shaon9902 in forum AutoCAD Map 3D - General
    Last Post: 2006-10-18, 07:57 AM
  5. Disappearing cursor
    By rhayes.99001 in forum ACA General
    Last Post: 2005-11-11, 01:33 PM
