Results 1 to 7 of 7
Thread: Imported dwg hatches turn solid black
    Member gmg's Avatar
    2006-04
    San Diego, CA
    10
    Default Imported dwg hatches turn solid black
    Has anyone found out why certain AutoCAD hatches (that are not solid fill in the dwg file) import into Revit as a solid black fill? Sometimes I can get around it by changing the hatch scale in AutoCAD and reimporting it. Other times I have to explode the hatch and it appears correct in Revit. If anyone knows of a better solution please let me know.
    2015-11
    151
    Default Re: Imported dwg hatches turn solid black
    Nope. I'd like to know too.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    I think its due to acad patterns being drafting pats so they scale wrong in revit. You see people who early in revit use a drafting pattern for a surf pattern and it gets too dense. I would experiment with ltscale or something in cad to make it work.
    Scott D. Brown, AIA
    BECK
    "Rock-n-Roll Architect" SCShell's Avatar
    2004-01
    Tucson, AZ
    1,272
    Hey there,
    You can also change the scale in Revit when creating it.
    Good Luck
    Steve
    Steven C. Shell, Architect
    Tucson, Arizona
    www.scshell.com
    2007-03
    Phoenix
    261
    First, it sounds like a scale issue of the hatch in DWG. Second, I would check to make sure that none of the hatches from a previous import have the same name potentially when they import as filled regions and therefore are begin overriden to solid or a different pattern. For example, the same file imported by someone else who did a partial explode and grabbed all the filled regions with that name and changed the properties? Just a thought.
    -LC
    Member mysixstring's Avatar
    2006-01
    Halifax, Nova Scotia
    16
    Sorry to bring up an old post but...
    I just discovered that you can avoid the whole Autocad hatches coming in as black solid fill by importing the dwg file at a custom scale much larger than the proper scale and then resizing the dwg down to the proper size after it has been imported. I have yet to find the down side of this method, there always is one, but as soon as I do I'll let you know.
    2003-05
    Coast to Coast
    4,440
    Great tip!!! Its funny because you do the opposite to bring in large site models, I scale them down to get past the 2 mile limit, then scale them up again.
    Scott D. Brown, AIA
    BECK
  1. Moving solid hatches to back ground
    By WAC-JB in forum AutoCAD General
    Last Post: 2010-06-24, 05:19 PM
  2. hatches from imported background files
    By lcohen in forum Revit Architecture - General
    Last Post: 2008-12-02, 03:30 PM
  3. imported tif is black
    By kscolfer in forum AutoCAD Map 3D - General
    Last Post: 2008-04-01, 02:12 PM
  4. Replies: 5
    Last Post: 2008-03-16, 07:00 AM
  5. Solid Hatches Do Not Display in Hidden Mode
    By libbybapa in forum ACA General
    Last Post: 2007-10-29, 10:56 PM
