david_peterson
Well 2 options for you.
A,) you could render it in ACA and apply that to your sheet via the image manager.
B.) you could get the view/angle you want, switch to a hidden mode and use the "createhlr" command to create a 2d block that you could then paste on the cover sheet just like anyother block.
Oh, and here's the 3 option.
You could put your composite model in your cover sheet file as a view.
Just some thoughts.
As far as sketch-up goes, you can get the basic version for free. I don't know that you can import cad files into it. I think there's a way to get that same "sketchy" feel with ACA with the display reps that became available in 2007 or 2008. I'm not sure which one..
