Results 1 to 10 of 18
Thread: Move an attribute with visibility states
    Turlock, CA
    6,420
    Default Move an attribute with visibility states
    I've searched this forum and can't seem to find what I'm looking for. I'm working on a db of a wire tag that has six positions (see attached). Right now it has six atts, and only one gets filled in upon inserttion. I just want one to move with each vis state, or is there a better way?
    C:> ED WORKING....
    LinkedIn
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: Move an attribute with visibility states
    hmmmm, short of getting it down to one attribute somehow using a lookup, i can already see it being down to no less than 2 states using flips anyway, but only if you don't mind a middle justified attribute.
    1 state for middle ones, the other for offset (each corner)
    what do you think?
    oh, and how tagged, what kind of text is used? (fishing for length issues)
    also, (and i'm sure you're still in the middle of developement and haven't gotten that far...) you'll need to make each tag unique in the DB regardless of visibility...
    S&D DB Sharing Forum
    Turlock, CA
    6,420
    No more than 15 chars, but usually 3-6.
    Would it work to have one invisible attribute, and then 6 fields for each location?
    C:> ED WORKING....
    LinkedIn
    2001-12
    Rochester, MN
    2,561
    i've done that, and it makes for a REALLY finicky block. as soon as somebody copy/pastes one of those blocks (at least in our office), it's nuthin but "######" signs everywhere!
    Turlock, CA
    6,420
    Quote Originally Posted by Chris.N View Post
    The attached seems to work, but the fields won't update after I change the attribute value.
    C:> ED WORKING....
    LinkedIn
    2001-12
    Rochester, MN
    2,561
    even after regens?
    fieldeval set to 31?
    ok, just looked and everything should be an attribute. have you had this setup work for you in the past?
    you can't have the 'child' attributes set to constant either for some reason, so i always put in the prompt field for the attributes DO NOT EDIT THIS LINE!!
    it seems to work for those that can read...
    Turlock, CA
    6,420
    Si, Si, senor. However, it will while in the block editor, just not after its inserted.
    C:> ED WORKING....
    LinkedIn
    Turlock, CA
    6,420
    I have a wishlist item that's been approved. Be sure to vote for this one.
    C:> ED WORKING....
    LinkedIn
    I could stop if I wanted to Ammon's Avatar
    2005-06
    Salt Lake City, Utah
    423
    Thanks for the info. I will definitely be voting for that one.
    150700
    3,439
    Quote Originally Posted by Ammon View Post
    ~insert shameless plug~
    You've only got until Monday to vote!!
  1. visibility states
    By luislhss in forum AutoLISP
    Last Post: 2013-06-27, 06:56 PM
  2. Layer States to Visibility States?
    By Ant59 in forum AutoCAD General
    Last Post: 2009-07-07, 11:17 AM
  3. Common Attribute amongst a couple visibility states
    By alaskahick in forum Dynamic Blocks - Technical
    Last Post: 2006-11-17, 03:13 PM
  4. Replies: 3
    Last Post: 2006-04-04, 05:46 PM
  5. Multiple visibility states??
    By blaine.67000 in forum Dynamic Blocks - Technical
    Last Post: 2006-01-30, 03:59 PM
