Results 1 to 6 of 6
Thread: Dyn Block annotations float around
    Active Member jaroguy's Avatar
    2005-11
    Minneapolis
    76
    Default Dyn Block annotations float around
    I have created several symbols in ADT 2006. Elevation, Section, Title. Most of the time they work great. But sometimes when you copy/paste the symbol into a different drawing, the annotation text will move! I have attached an image and a dwg of the actual block. When you open it up two of the annotations are in the wrong location, but it looks fine in block editor. Anyone run into a similar situation? Thanks in advance
    Jason
    2005-06
    in the upper right corner
    3,507
    Cool Re: Dyn Block annotations float around
    Quote Originally Posted by jaroguy View Post
    Jason
    Not sure what the problem is, when you insert the same block reference within your sample drawing it comes in fine.
    Is is possible that the attributes are using a text style that's being modified in different drawings? That may explain that a perfectly good block being pasted into a drawing with a modified text style, the attributes could go wacky.
    Just a thought.
    BTW, when you use "battman" and sync the attributes to that block reference, it fixes them.
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Re: Dyn Block annotations float around
    It might have to do with the fact you created the attribute with a locked location. I seem to recall that causing issues when I was playing around with attributes previously.
    Since this is really a core AutoCAD functionality item, I would like to recommend moving this to the AutoCAD DynBlocks forum as you will get better help there on this subject. Let me know if you would like me to do that.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    your attributes have the same names - which can cause a lot of headaches. most of that really looks like you just need to sync your block(s).
    2005-11
    Minneapolis
    76
    Syncing the block works when I am in the resourse drawing but it doesn't stick when I have inserted it into a background or sheet file. It looks good when I hit the sync button in the Block Attribute Manager dialog but when I hit the ok button to exit the dialog the block Un-syncs.
    And as far as the attributes having the same names, are you talking about the values of the attributes?
    2006-04
    1,129
    you have several attributes named:
    X
    X_XX000
    if you rename these it should help out a lot.
  1. Calculation of float station
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2010-10-07, 01:24 AM
  2. Float vs Decimal
    By BeKirra in forum AutoLISP
    Last Post: 2008-11-27, 06:56 AM
  3. Remove Annotations from a Dynamic Block
    By d.leigh in forum Dynamic Blocks - Technical
    Last Post: 2008-10-29, 04:50 PM
  4. Multiple Annotations for one Note Block
    By cdchristian in forum Revit Architecture - General
    Last Post: 2007-08-17, 09:48 PM
  5. Chairs Don't Float
    By mailtomac1860 in forum Revit Architecture - General
    Last Post: 2003-12-22, 07:43 AM
