Results 1 to 10 of 12
Thread: Desk - A2008
    I could stop if I wanted to ronie_ernanto's Avatar
    2006-11
    Jauh di Sidoarjo sana (Indonesia)
    312
    Default Desk - A2008
    Render time : about 30 mins
    Light : 2 artificial lights
    GI & Final Gather : on
    Machine : Pentium Core Duo 2.8, 1 GB RAM.
    I did it for fun..........
    Critics are wellcome....
    2006-08
    34
    Default Re: Desk - A2008
    Nice work...
    I have no criticism, actually I have a question,
    I have been trying to work out the best lighting settings to use for indoor scenes in 2007,
    Could you tell me which shadow and lighting options you used on this render, they give a nice realistic feel to the render.
    I assume the lights were positioned one above the desk and one behind the camera?
    For an extra touch I would have added a skirting board (but maybe that country specific)
    Nice touch with the monitor by the way
    Português - Programação Moderator Filipe Francisco's Avatar
    2001-12
    * PORTUGAL * Sintra *
    859
    Really nice,
    good job
    Cheers
    2006-11
    312
    Quote Originally Posted by nlegge View Post
    Nice work...
    thx
    I render this with 2008, as 2007 could not give photometric lighting effect.
    if you use 2007, there's should be more than 20 light sources (I usually use at least 28 light source for 4x4m room) to get the best result, but it still far if compared with 2008.
    For this render I use 2 light sources on ceiling (height about 3.2m, room size 4x5m), incandescent lamp, intensity 0.1, light intensity 0.1 too.(don't forget to turn lighting unit to international/american to change to photometric lighting mode). render preset high, sampling rate 3 or 4, and of course GI & Final Gather turned on.
    Hope it will help you.
    2006-08
    34
    I am glad I wasn't doing anything wrong then..........
    20 light sources!! that would take an age to render!!!
    I have a quick machine (AMD X2 6400+ (3.2GHz) 2gig of fast RAM etc) but when I start adding lights the render time starts to get silly.
    I assume they have fixed that in 2008 as you said it only took 30mins
    I will continue to play...... I will get there........
    2005-07
    Myanmar
    192
    Unhappy Re: Desk - A2008
    Quote Originally Posted by ronie_ernanto View Post
    Hey my friend,
    I have problem for rendering with 2008.When i was rendering with 2006 or older... I would get faster render time with surface model and slow render time with solid model.How i do to fast render with 2008.My laptop is core duro 1.6, 1G,graphic memory 256 and window vista.Attach image give render time about 15 minutes (final gathering is turn off).Next pls give best shadow type and setting.....Thk
    2006-11
    312
    no, I mean I did it without photometric light and usually only 4 that has shadow,others without shadow. rendering with my machine will take approx 5-10 mins
    2006-11
    312
    Quote Originally Posted by spacedecor View Post
    Hey my friend,
    On my experience, render time only depending on transparent object, number of lights, number of shadows, type of shadow,GI & Final gather option, and number of ray traced.
    if you want to reduce render time, reduce those factors.
    i think 15 minutes is a reasonable time.
    2004-07
    Detroit Michigan
    2,508
    Nice work. Build me one of those desks. Nice, simple, and doesn't take up
    too much space.
    2006-11
    312
    Quote Originally Posted by Robert.Hall View Post
    too much space.
    I can build it for you,but how you pick it up? I'm in Indonesia, more than 10.000 kms away from you.
  1. Pantry A2007-A2008
    By ronie_ernanto in forum AutoCAD Gallery
    Last Post: 2008-06-10, 09:58 AM
  2. Living Room is made by A2008
    By spacedecor in forum AutoCAD Gallery
    Last Post: 2008-04-25, 11:26 PM
  3. Rendering setting for A2008
    By spacedecor in forum AutoCAD Tips & Tricks
    Last Post: 2008-04-25, 07:13 AM
  4. Livingroom - A2008
    Last Post: 2008-03-28, 07:06 PM
  5. Bedroom-A2008
    Last Post: 2008-03-21, 04:53 AM
