Results 1 to 10 of 16
Thread: Default field values
    2007-11
    7
    Default Default field values
    I'm using a title block that was created by an architect and has multiple lines of attributes for the sheet title, most of which, will be empty.
    I have set up the attribute values as a field CurrentSheetCustom with each having a unique Custom Property Name. When the block is inserted onto teh border the null values resort to the default value (----). How can this be changed to show the field as null?
    2002-09
    Madison, WI
    5,687
    Default Re: Default field values
    Just as a thought, I'm thinking that the reason that those are showning the --- is because there's no data entered. I'd try entering a space via the space bar in the empty attribute values.
    Just a thought.
    2007-11
    7
    Tried adding the space but on REGEN autocad removes the space and replaces value with the field's default value.
    2002-09
    Madison, WI
    5,687
    Then I guess I'd remove the field and just leave the attribute blank if it's not being used. Fields require information from my understanding. I guess your other option would be to create a pen style (or color) that dosen't plot and set the text of the field to that color. You'll still see it that way but it won't plot. I'll tell you I'm not the expert on field around here so you may want to hold off and hope for more responses. Are doing through PN or a different method. If it's more of an Acad thing than an ACA thing I can move the thread to a different forum for you if you like.
    2007-11
    7
    Whatever it takes to get this problem solved is fine with me. I'm getting to the point of dropping the sheet set manager altogether.
    2002-09
    Madison, WI
    5,687
    Please note, I've moved your thread to the Autocad Fields forum.
    Brisbane-Australia & Phoenix Arizona
    80
    I wouldn't drop the sheet set manager. (or Project Navigator in ACA) The PN is a vital part of the ACA workflow. Just don't go overboard with fields. The way I have my titleblocks setup is with all static info in a xref.(Project name, address etc.) Only the variable info is done with fields. (drawing title, drawing number, revision etc.)
    2,095
    Will putting in a full stop "." as a default work? Something that is not prominent, but will still allow for directly setting the attribute?
    2007-11
    7
    Quote Originally Posted by dgorsman View Post
    I looked at using "." and using different layers but it's a sloppy fix. you should be able to have a blank field without a lot of work or fixes that could come back later and bite you.
    As for the \U+00A0 and <ALT> 0160, I tried putting those in the individual sheet properties of the sheet manager and I get what I typed or I get the default "----".
    2002-05
    Markham, ON, Canada
    64
    I'd like to see a proper solution to this also - I thought AC2008 would have fixed this, but alas no
    My current workaround is to edit the field with the period (.) or ---- to change its colour to 255, making it invisible when printed, obviously this is no use if you need to see the field on other copies of the block..
  1. Highlight field for multiple varying values
    Last Post: 2014-11-13, 05:22 PM
  2. 2013: Multiply Schedule field values
    By Spork in forum Revit Architecture - General
    Last Post: 2013-04-09, 01:05 PM
  3. Field Values in Xref not Displaying Correctly
    By sifuentes in forum AutoCAD Fields
    Last Post: 2010-04-08, 03:22 PM
  4. object field values scales with VP?
    By randyspear in forum Dynamic Blocks - Technical
    Last Post: 2010-03-17, 03:26 PM
  5. Replies: 3
    Last Post: 2007-03-27, 06:13 AM
