Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Default field values
  1. #11
    2015-12
    2,095
    Default Re: Default field values
    Will putting in a full stop "." as a default work? Something that is not prominent, but will still allow for directly setting the attribute?
    If you are going to fly by the seat of your pants, expect friction burns.
    Some say beauty is in the eye of the Beholder... perhaps so, but I've only seen the disintegration beam.
    Everyone else being wrong is not the same thing as being right.
  2. #12
    2007-11
    7
    Quote Originally Posted by dgorsman View Post
    I looked at using "." and using different layers but it's a sloppy fix. you should be able to have a blank field without a lot of work or fixes that could come back later and bite you.
    As for the \U+00A0 and <ALT> 0160, I tried putting those in the individual sheet properties of the sheet manager and I get what I typed or I get the default "----".
  3. #13
    Active Member bcowper's Avatar
    2002-05
    Markham, ON, Canada
    64
    I'd like to see a proper solution to this also - I thought AC2008 would have fixed this, but alas no
    My current workaround is to edit the field with the period (.) or ---- to change its colour to 255, making it invisible when printed, obviously this is no use if you need to see the field on other copies of the block..
    Brian Cowper
    AutoCAD Map 2008, Civil 3D 2008, LDD 2008, Raster Design 2008.
    Other software: Manifold Universal 8.0, ArcGIS 9.2, Surfer 8
    Manifold Blog
  4. #14
    2006-02
    Thanks gab_frgz! This solved my issue. Instead of a space, which is automatically removed, i wrote \U+00A0, and the Field appears blank. No (----) anymore.
  5. #15
    Cairo - no, not Illinois
    4,782
    Generally, i'll use %% as the default value in SSM. That shows up as nothing in the drawing, and is a bit shorter than \U+00A0
  6. #16
    2015-10
    Central New Jersey
    414
    I've been using the name of the SSM field as the default value. It leads the user to the correct value they need to edit in order to fill in that line of the title block. In the SSM template, one of the SSM fields we never use I have an instruction to use %% for a blank value.
  1. Highlight field for multiple varying values
    Last Post: 2014-11-13, 05:22 PM
  2. 2013: Multiply Schedule field values
    By Spork in forum Revit Architecture - General
    Last Post: 2013-04-09, 01:05 PM
  3. Field Values in Xref not Displaying Correctly
    By sifuentes in forum AutoCAD Fields
    Last Post: 2010-04-08, 03:22 PM
  4. object field values scales with VP?
    By randyspear in forum Dynamic Blocks - Technical
    Last Post: 2010-03-17, 03:26 PM
  5. Replies: 3
    Last Post: 2007-03-27, 06:13 AM
