Steve, if the cap fits wear it Moot-boy.
moot-boy.... that's a good one.Originally Posted by PeterJ
I too would like to see some control but also some flexibility. I think somewhere between level 2 and 3. Level two for specific manufacturers content and level 3 for generic-general use families made by a "content provider"
Chris
SOM | New York
Is it not something which could be made optional thus the creator could have access to a dialog box much like the visibility box allowing you to check options for differing levels of control?
Isn't this issue present now with manufacturers or third parties providing blocks and drawings in .dwg format? Why would providing families be any different from a liability standpoint? Or am I missing something? Can .dwg files be locked? (As I said in the previous thread we don't use third party stuff other than manufacturer's details.) In case I am displaying my ignorance here I will be embarassed in advance. ops:Originally Posted by PeterJ
Internal Memo
TO: Z
RE: Mean Mistah Jay
Uh..Z, I can't seem to find the ZD employee complaint form? Did you move it?....oh, and you shouldn't encourage Mistah Jay. Remember you are the boss now and you have to LEAD by example!!
This has been a brief comedic interlude, you may return to serious matters
Originally Posted by Steve_Stafford
re: inernal memo
Memo to staff:
get back to work before i fire the lot of you <whip>
Z
Chris
SOM | New York
Yes, in AutoCAD 2004 you have "digital signatures" - but that is not optional by type of modification/save. David's 1,2,3,4 is much more complicated.Can .dwg files be locked?
I agree with czoog that an option of 2 and 3 would be best.
About #2: Some manufacturers I have talked to have been burned by copy-cat producers. One has even gone to the trouble of copywriting each of their designs. (and paying lawyers to enforce it, I guess)
About #3: For those valuable "generic" families, the author of the work would want to get the credit (and the blame?)
I don't get the fuss.. who's talking about creating content for an architect's or building office?? that will -never- work or be copy-proof or something, and it doesn't have to.
Autodesk says, quite logically.. you could create content for product manufacturers, here copyright is NOT an issue at all.. the manufacturers simply want their content to be as wide-spread as possible. If other rebuilt their content to their needs, who cares? The only things you might want to 'lock' into the family is the original content manufacturer and the company [+hotlink] it has originated from.
Call me crazy..
RobertOriginally Posted by bclarch
I don't know that the liability issue changes necessarily, but if a manufacturer creates a family it will get used from day one. In the dwg world if you make a window detail, maybe even an elevation block and a pan block, probably I will not use them at the scheme design stage as the windows don't need to be pinned down at the outset and I will be drawing details as a separate sheet, probably in a separate file. On the other hand if you give me a family I might use it from the outset because I won't want to change it during the drafting process if I don't need to and I will be adding greater detail within the same model as I go along. If the family is not right at the outset I may not wish to import a dwg to a detail sheet to indicate a detail I am not going to adhere to.
Overall my argument is more about needing families when the project is at scheme design stage than it is about whether details are correct etc.
P
I'm not too sure many manufacturers would care about this, for example every big windoe mfg produces a CD of thier own windows and details, any cad user could copy those and edit them as needed. Why is a revit family any different. Someone took the time to draw those elevations and details in autocad, now someone will do it in revit. NO big deal.
If it is a big deal, then I would like a way to still modify the families you purchase, windows are an easy example where you would have diff. trim options you may try(maybe this could be handled with nested families, but I see problems just like today that the mfg creates all this content that we rarely use because its on the wrong layers or in revits case wrong object styles, can you imagine all the object styles that would be in a project if you had mfg content from multiple mfg all creating families with their own rules??? sounds like the layer nightmares of the past.
As this developes, Revit should set standards for diff object types(as they have allready)
Just my thoughts.
Scott D. Brown, AIA
BECK
