Thread: Derive and Replace Part/Assembly
    Wish List Administration
    2006-03
    1,102
    Default Derive and Replace Part/Assembly
    Summary: Be able to derive a part or assembly into a new part and then replace the original with the derived part
    Description: Derive N Replace. Whilst working in an Assembly I need the ability to derive a part or sub-assembly into a new part file and then replace the original in the assembly with the derived part
    How Used: Charles Bliss has a very good add-in called Save N Replace, I am find more and more often the need to derive a part and replace the original with the derived. This comes about from one of two reasons; I've been working-up a "quick and dirty" design with two or more instances of the same component, one of more now need editing. Or I need to add features - such as machining that I need to show in new drawing for that part as a separate manufacturing process. I sometimes use derivatives to show separate manufacturing stages and I have a problem doing this if the part is already in an Assembly.
    Feature Affinity: Assemblies
    Submitted By: Duncan Anderson on October 1, 2007
    2011-08
    4,581
    Exclamation Re: Derive and Replace Part/Assembly
    This wish has been reported as granted and already in the software.
    2011-08
    4,581
    The wish has already been granted. This thread is closed to further posts.
  1. 2015: Can I derive a part from the content center?
    By crullier in forum Inventor - General
    Last Post: 2015-01-20, 09:53 AM
  2. Derive same part but different dimensions
    Last Post: 2014-12-05, 10:23 PM
  3. To allow replace Base View Part or Assembly
    Last Post: 2012-09-03, 03:10 PM
  4. Derive Work Sufaces from an Assembly
    Last Post: 2006-11-06, 03:59 AM
  5. Replace a part in a drawing with an assembly.
    By jdovel in forum Inventor Wish List
    Last Post: 2005-11-28, 01:13 PM
