Anyone know how to rotate the viewport in layout?
thx a lot
Jack Cheong
thx a lot
Jack Cheong
I have a lisp routine that I run that does it quick and easily.
DVIEW works really well, as mentioned above. An alternate is to rotate your UCS as needed, then use the command PLAN. Sometimes I think this is simpler than DVIEW.
I created a button and use the following macro. Use it within floating model space.
1. Click the button,
2. select a center point in the viewport for rotation.
It will rotate the viewport 90 degrees. Repeat for 180, 270, etc. If you end up doing this frequently, create a second button that rotates clockwise. I chose zoom settings that work well for me and my work. You may want to tweak it to your needs.
There are fancier ways to do it, but this way works for LT and the full version.
^C^C_UCS;N;none;\ucs;z;90;plan;;z;s;1/24;z;c;0,0;;ucs;;ucs;v;
