All of a sudden I am getting this error when veiwing a map set or after every drawing when I plot a map set. This just started yesterday, no changes to the project or updates/ modifications of any kind to the PC. When I click 'plot map set'/'view map sheet' everything displays as it should it loads my layout, install borders /title block, and inserts drawings as it should. After everyting is loaded it gives me the option to click 'plot' or 'done'. After clicking either, everything seems fine, it plots if I choose to or closes the drawing if I choose 'done'as it should, then I get a fatal error message autocad aborting 'unhandled access violation reading 0x0014 at 30096ea0h. It does this for every drawing in the selection set. What could cause this to happen now?
Blair
