Thread: mpedit troubles .....
    2001-04
    Unhappy mpedit troubles .....
    Everytime I use MPEDIT, all my OSNAPs get cleared and I have to set them again, but if I do an PEDIT then MULTIPLE I don't get this problem.
    I'm running 2002.
    Thanks !!
    2015-12
    Arizona
    2,478
    Default Re: mpedit troubles .....
    13,656
    Hi
    Give the below a try, is from a pre WittyWorm Forum post that I made when this question was asked before (offers a simple solution to get round the problem) -
    (defun c:PEM (/ SSet)
      (setq SSet (ssget "_I"))
      (if (= SSet nil)
    	(progn
    	  (command "._Pedit" "_M")
    	  (while (> (getvar "CMDACTIVE") 0)
    			 (command pause)
    	(progn
    	  (command "._PEdit" "_M" SSet "")
    			 (command pause)
      (princ)
    Have a good one, Mike
  1. 2012: Polyline editing: PEDITACCEPT = 1, the PEDIT command VS. the MPEDIT command
    By Boozbaz154610 in forum AutoCAD General
    Last Post: 2013-01-29, 01:20 PM
  2. .COM troubles
    By rhutchi1 in forum VBA/COM Interop
    Last Post: 2012-09-19, 02:39 PM
  3. Puzzled by mpedit?
    By ddempsie in forum AutoCAD General
    Last Post: 2007-11-12, 01:31 PM
  4. Elevation troubles
    By h.jobe in forum ACA General
    Last Post: 2006-08-25, 05:35 PM
  5. Macro using MPedit clears all OSnap settings
    By jonathan_fairholm in forum AutoCAD Customization
    Last Post: 2005-01-28, 01:52 PM
