Results 1 to 7 of 7
Thread: Auto Update of Northing/Easting when object is moved
    2007-11
    Florida
    7
    Default Auto Update of Northing/Easting when object is moved
    I often work with drawings of coastal areas, the location (Northing, Easting) of a number of objects is displayed on the layout in a tabular legend. I was wondering if it was possible to somehow link the table to the object it references. What I am trying to accomplish is to have the ability to move an object in the drawing (such as a navigation aid), and have the table that gives its text location automatically update with the new coordinates. I am still using ID to get the new location and then updating the table manually.
    2003-12
    Pittsburgh, PA
    355
    Default Re: Auto Update of Northing/Easting when object is moved
    Consider using Fields in your table. In the attached screen capture image I've created a table using the position of a Point object as the Fields' property. If you move the Point and regen, the table will update using the new coordinates of the Point. The referenced object doesn't necessarily have to be a Point, it can be a Circle, Block...
    All AUGI, all the time Capt. Computer Crasher's Avatar
    2006-12
    South of North & East of West
    786
    here is a link to the fields forum for more help:
    http://forums.augi.com/forumdisplay.php?f=53
    also a link to the tables forum:
    http://forums.augi.com/forumdisplay.php?f=199
    To create a field in click a piece of text, Mtext or a table cell to edit, right click in the editor then pick insert field.
    In the following dialog box:
    Field category >>>>>> objects
    Field name>>>>>>>>object
    Object type >>>>>>>>hit the pick icon on right and choose object
    property>>>>>>position
    format>>>>>>decimal
    precision>>>>>>>0.00 (or however you want)
    list seperator>>>>> this indicates what is use to seperate the x, y, z, coordinates (semi-colon, comma, slash) this is if you have more than one coordinate box below it checked. if only one box is checked there is no seperator. (I suggest using seperate fields one for each coordinate).
    under the "Additional Format" icon you can place a prefix (x =, y =,z =) and/or suffix (ft, m, etc.) if you wish
    Hope this helps.
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    If the objects that are listed in the table are blocks I would recommend using AutoCAD tables and data extraction. If they are not blocks go with the fields suggestion.
    2006-12
    786
    Quote Originally Posted by jpaulsen View Post
    In AutoCAD 2008, they don't have to be blocks. They can be any AutoCAD object.
    2002-04
    Colorado
    2,020
    You are correct. We dont use this feature much so I forgot they tottaly revamped it in 2008.
    2007-11
    Florida
    7
    Thank you for your response, the fields option worked perfectly! It will save me a considerable amount of time, as I perform that function quite often.
  1. ID Northing/Easting In C3D
    By jimmyhill in forum AutoCAD Civil 3D - General
    Last Post: 2016-01-26, 11:00 PM
  2. labeling northing & easting on an alignment
    By Maverick91 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2012-03-29, 04:02 PM
  3. Alignment Table = Sta: Northing Easting
    By chris.little in forum AutoCAD Civil 3D - Alignments
    Last Post: 2010-04-15, 04:19 AM
  4. Northing & Easting
    By gmarshall.222707 in forum Dynamic Blocks - Sharing
    Last Post: 2009-08-11, 10:02 PM
  5. Northing/Easting snap to column
    By 4hoursstanding in forum Revit Structure - Wish List
    Last Post: 2007-03-13, 02:48 AM
