Thread: Phasing & Graphic Overrides
    Member gmak's Avatar
    2004-05
    London
    26
    Default Phasing & Graphic Overrides
    Hi,
    I have some stairs that are in the 'existing' phase. When looking at the 'existing' view the stairs and rails appear fine (with dashed lines for the steps and railings above the cut plane, etc). However, when I look at the 'proposed' views (shownig existing + new), the stairs appear as solid.
    Is there a way to get the stairs to appear correctly in the proposed view without having to have all of the existing looking like the proposed (with hatching, etc)? I can't seem to find a way to fine tune the graphic display for juts the stairs.
    Thanks.
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    Default Re: Phasing & Graphic Overrides
    It appears that you have made changes to the standard view settings (everything on) to switch the visibility of things key V V or go to View Visibility settings and uncheck the sections of the stair vesibility settings that control visibilty beyond cut line. You can also look here at using overrides if you are unhappy with the 'above' line pattern that it will then automatically apply.
    2004-05
    London
    26
    Ah, yes. That's exactly what I needed. I've only ever used the View Visibility setting to turn on whole groups of things, not to get that fine about it.
    Thanks
  1. 2010: Phasing Graphic Overrides problem
    By favi.rietti604567 in forum Revit Architecture - General
    Last Post: 2014-04-21, 05:01 PM
  2. Graphic Overrides in Phasing
    By nosslok in forum Revit Architecture - General
    Last Post: 2009-07-02, 03:49 PM
  3. Graphic Overrides & Phasing
    By ford347 in forum Revit Architecture - General
    Last Post: 2005-11-22, 08:14 PM
  4. Phasing graphic overrides
    By rjjlee in forum Revit Architecture - General
    Last Post: 2005-09-12, 01:06 AM
  5. Graphic overrides for phasing.
    By Paul Monsef in forum Revit Architecture - General
    Last Post: 2004-03-19, 08:23 PM
