You can get object enablers from here.
To see if there are any there set "fielddisplay" to 1 fields will show up with a grey background.Originally Posted by help file
I would go with Tracey and Steve's suggestions first and the object enablers from Autodesk
I'm assuming so.
~snip~
Utilities & Drivers
AutoCAD LT® 2008
- AutoCAD LT® 2008
- AutoCAD LT® 2007
- AutoCAD LT® 2006
- AutoCAD LT® 2005
- AutoCAD LT® 2004
- AutoCAD LT® 2002
- AutoCAD LT® 2000i
- AutoCAD LT® 2000
- AutoCAD LT® for Windows 95
~snip~
I must admit that I've never tried them as had full version for a long time.
I have fixed the link on the previous post.
I did have the object enabler already but to be sure I have reloaded the enabler. HOwever I still get the message re showing proxy graphics is this correct?
the purge command will removed all unused drawing properties, including unused blocks, when you have finished purge command there are only used blocks left on the drawing, you can check the blocks using the properties command to select whole blocks , then acadlt will display some/whole match blocks highlighted on the screen, except for the blocks that nested to other block.
yes right, the drawing that has created on the other application though produce by autodesk will sometime caused unpredict result when open in LT, run out of memory are the most case, maybe becos LT doesn't support the object enabler..
For anybody's further information the message I get when I open the architects drawings says the following (basically)
Missing Applications AeccLand30, AeccNetwork30 & LAN_AEC30COL
Product used Autodesk Civil 3D
Does this help?
I have heard of other LT users saving down to R12 (as a different file name), and that apparently gets rid of the proxies... I dont know what happens to the actual information, whether it becomes dumbed down lines etc, or what happens...
