Results 1 to 10 of 14
Thread: Drawing Sheet Notes - A Different Approach
    "Rock-n-Roll Architect" SCShell's Avatar
    2004-01
    Tucson, AZ
    1,272
    Default Drawing Sheet Notes - A Different Approach
    Hey there,
    This is a different method of placing drawing sheet notes on a title block sheet.
    (The traditional method has been to simply "copy and paste" your notes from WordPerfect, MS Word or other text editor; however, you lost any formating other than the first paragraph indent after the number. Secondly, if you have a column of text which is longer than your sheet, you have to "cut and paste" or paste another column and delete text in order to carry over into the next vertical column of you sheet.)
    This method was shown at AU2007 in T.J. Meehan's "Templates" course:
    Create a "keyed schedule", then,
    Set your columns for a number and another column for your text.
    Copy and paste your text into the text column, one by one. (A little bit of a pain; but worth it maybe!)
    Once you have all of your notes pasted, with the number......sort by number and put it on your sheet. You then can adjust the length of the rows and, because they are schedules, you can now split your schedule in the event that the schedule is longer than the sheet.
    The only other advice which was mentioned is:
    If you have to go back and edit your schedule, you may want to do your actual editing in the original text document rather than in your schedule. Then, just paste it back in again. (Remember, schedules only place text in one long text box without any word wrapping. Kinda hard to see the whole note.)
    What you get now is a nice looking set of notes, where each paragraph is "paragraph indented" and the length and width is very controllable.
    Thanks to T.J. Meehan at AU!
    Steve
    All AUGI, all the time archjake's Avatar
    2003-07
    Tucson, AZ
    531
    Default Re: Drawing Sheet Notes - A Different Approach
    Will the spell check work with this?
    2005-11
    60
    How is this easier than just using 2 blocks of text beside each other; 1 for the numbers, 1 for the notes? The notes will wrap if you change the width. You just need to add blank lines between the numbers so they'll line up with the text. If you want the lines of each schedule cell to show up, this would be worth it. (I hate the idea of having to go back and forth - I'd rather fight the text a little bit directly in Revit). Now, if there were a table feature, with excel linked into it. . . .
    2004-01
    Tucson, AZ
    1,272
    Quote Originally Posted by atbergma View Post
    Hey there,
    That is certainly another approach. I didn't say it was easier, I just said it was another option for those folks who wanted a bit more control over the paragraph indent format.
    Thanks for the input.
    Steve
    2006-11
    Auckland, New Zealand
    92
    I think this approach works well - but can you make certain words within the key schedule bold?
    2004-01
    Tucson, AZ
    1,272
    Hey there,
    When I played with this, I noticed that you can't use spell check in a schedule, nor change just one word's font style in a schedule, ie, bold etc.
    But, it was recommended that you do all of your actual typing and edit work in the word processing program that you used to generate the schedule.
    Good luck
    Steve
    2006-11
    92
    Hi Steve
    I've tried editing the text within a word processor (word to be exact) but once i had brought it back into Revit key schedule the formatting disappeared.
    Will keep working on it and if i find a solution, i'll be sure to post it on here.
    Melanie
    I assume this is referring to using user key notes.
    The key schedule is based on a .txt file so cannot have the same formatting options as in word. However, it's a lot better than using text boxes because they only show the notes that you have called out with the key symbol in the drawing; they are smart, in other words.
    One major problem: they are a bit too smart. If you delete a keyed note, it will renumber the notes and they corresponding symbols to match. This is not good when you have already issued a construction set and are just trying to make some revisions as there will be a lot of 'apparent' changes, even though the content really hasn't changed.
    Don't ask me how I know this.. One work-around might be to replace the keyed note text in the schedule with "not used" rather than deleting it but I haven't tried to implement this. I will most likely NOT be using key notes this way until I (or autodesk or someone else) solves this.
    2004-01
    Tucson, AZ
    1,272
    Quote Originally Posted by tyler.kawahara View Post
    Hey there,
    Actually, I was not referring to keyed notes. I was using general drawing sheet notes as the example; however, you brought up a good issue. I had not thought about that.
    Thanks
    Steve
    2008-05
    Yardley, PA
    305
    I came up with a solution to the 'can't indent' It is more like an illusion, but it will work...
    start by Create 4 numbering columns... and then your text columns
    First column will be hidden so you can put in the numbers and sort the rows correctly. (add a few more blanks then you need so when you can't remember you have a hidden column and time is short you can at least put in a few new items.)
    Second column will be a number
    Third column will be any letters
    Fourth column will be a number again
    and then a column with the note.
    It works like the way word formats tabbed numbered bullets. And you can control the indents by resizing a column.
    Ex 01a1
    '01' will be in the second column 1st row
    a' will be in the third column 2nd row
    '1' will be in the 4th column 3rd row.
    You can put in dots on the empty slots on the right of your number or letter. Kind of like below
    01..TEXT NOTE
    a.TEXT NOTE
    1.TEXTNOTE
    The problem with this is that you note column will still be in line, but at least you can create the illusion of an indented text...
  1. General Notes/ Plan Notes/ Sheet Notes
    By ubviswa in forum Revit Structure - General
    Last Post: 2012-12-04, 05:32 PM
  2. Sheet Notes - Workflow
    By barathd in forum Revit Architecture - General
    Last Post: 2011-05-05, 08:07 PM
  3. Notes to sheet
    By mrdavie in forum Revit Architecture - General
    Last Post: 2011-04-05, 08:54 PM
  4. Sheet Notes Tab in the Sheet Set Manager
    Last Post: 2010-06-16, 05:43 PM
  5. Notes that refer to drawing number on sheet
    By Archman in forum Revit Architecture - General
    Last Post: 2005-07-30, 12:46 AM
