Results 1 to 7 of 7
Thread: Can Map be used as vanilla AutoCAD?
    2005-01
    21
    Default Can Map be used as vanilla AutoCAD?
    We've got a seat of Map 3D 2006 and need to switch it for a straight AutoCAD user. Can this be done and if so how? I remember being able to switch back and forth between the menus way back when but we haven't even touched Map in several years/versions.
    Thanks!
    150700
    3,434
    Default Re: Can Map be used as vanilla AutoCAD?
    Quote Originally Posted by mark.81576 View Post
    Thanks!
    I don't know Map specifically, but in other verticals if you check the profiles, there should be a "vanilla" profile. Also, check under the start button, there might be a pre-set shortcut for it.
    2005-01
    21
    Thanks, Brenda. After I posted I did find an option under the View menu to switch the Menu/Toolbar Layout between Map 3D and Map Classic which is apparently what we were looking for. The program then crashes but we're getting somewhere!
    Thanks again.
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Ninety-nine percent of what i do is using MAP3D as generic AutoCAD. I need some special tools in LDT but it won't allow more than one drawing open at a time.
    Autodesk Civil3D 2018, Revit 2018
    Gig 'Em, Aggies!
    100 Club Aquaserpent's Avatar
    174
    Type in SDI at the command line and set to 0. This will allow for multiple drawings to be open at the same time.
    Earth
    9,802
    Lightbulb Re: Can Map be used as vanilla AutoCAD?
    Quote Originally Posted by froose View Post
    The default setting for SDI is already zero (0) in MAP.
    R.K. McSwain | CAD Panacea |
    100 Club JeremiahM's Avatar
    Colorado Springs, CO
    186
    Maverick91
    they SDI variable will not change in LDT. if i remember correctly you should have had a shortcut called "Land Enabled Map" which was vanilla Map and all of its SDI glory!
    check your Windows Programs list and see if it exists. it might have been and option during install as well that you opted not to install.
    Jeremiah
    Jeremiah McKnelly, GISP
    www.spatialbiz.com
    Weapons of choice: Map 3D, AUD, AIMS and SQL!
  1. AutoCAD Electrical type Icon Menu in AutoCAD Vanilla !
    By iqbal.ahmad in forum AutoCAD General
    Last Post: 2009-04-15, 05:33 AM
  2. autocad vanilla
    By todd.205268 in forum AutoCAD General
    Last Post: 2009-01-09, 02:33 PM
  3. Section Callouts in vanilla AutoCAD
    By bmckenzie in forum CAD Standards
    Last Post: 2008-07-22, 08:13 PM
  4. Your Favorite VANILLA AutoCad Add-Ons
    By madcadder in forum AutoCAD Customization
    Last Post: 2005-10-06, 01:38 PM
  5. Vanilla Autocad rendered examples??
    By bjack56 in forum AutoCAD General
    Last Post: 2004-12-18, 07:37 PM
